How far can the 12A be stretched?
Old Oct 7, 2007 | 12:17 AM
BlackWorksInc's Avatar
Wrkn Toyota, Rootn Wankel
I am thinking of using the stock 12A out of my '82 for a while.
My question is simple; can I get 240-320hp out of the 12A? And can I do this with a N/A setup? Or would a turbo be more worthwhile?
Also, a very out there idea, but... What about the RX8 13B? That should fit in the engine bay with a little coaxing and I think with an NA setup or even a turbo I'd meet or exceed my power goal.
Any ideas?
Old Oct 7, 2007 | 12:33 AM
diabolical1's Avatar
what's your budget?
you can get the 12A ported and built, then turbocharge it to meet your goals. unless this is an all-out race car, that's the only way you're going to meet that power goal and keep it "streetable".
as for the Renesis swap ... refer to my first question.
Old Oct 8, 2007 | 07:10 PM
infinit1's Avatar
diabolical1 has the right question. the sky is the limit depending on budget. You can make well over 600 with 12a if you have the right knowledge and budget. hit up robert at www.rotaryshack.com
username: 680RWHP12A
He can do wonders with a 12a.
Old Oct 11, 2007 | 01:49 AM
nBOOSTe's Avatar
Any ideas?
you can put an rx-8 motor in your car....... all u need is the front 12a timing cover and a CARBUATOR, just make ur own manifold its been done in puerto rico- u dont need a COMPUTER or HARNES
Andrew7dg
Aug 6, 2017 01:41 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
