TII Boost control -- How's it work?
Old Apr 9, 2002 | 12:54 AM
Manolis_D's Avatar
What does the Boost Control solenoid on a TII do (besides control boost ) . Is it possible to control boost using a Haltech to actuate the solenoid? Looking at the diagram in the FSM, it seems like it would be possible to lower the boost (I'd like to be able to do that while I tune the car) -- is that possible?
Thanks!,
Manolis
Old Apr 9, 2002 | 12:56 AM
RETed's Avatar
Re: TII Boost control -- How's it work?
It pulses so that it bleeds off pressure to the wastegate actuator.
Yes, it is entirely possible to do so.
-Ted
Old Apr 9, 2002 | 12:59 AM
Manolis_D's Avatar
Thanks for the quick reply! Do you know how low a boost pressure you can get (assuming stock exhaust, etc.) if the solenoid was left open (closed?) all the way?
Thanks!
Old Apr 9, 2002 | 01:01 AM
RETed's Avatar
Short of restricting the exhaust or intake beyond reason, it should boost 5.5psi with an unmolested vacuum line.&nbsp This is the pressure of the spring Mazda stuffed into the stock turbos - both Zenki and Kouki turbo FC's.
-Ted
Old Apr 9, 2002 | 01:07 AM
Manolis_D's Avatar
Awesome -- THANKS Ted! Now to get that thing hooked up
cristoDathird
28
May 30, 2019 08:47 PM
