difference in na/t2 4.10 limites slip rears ?
Old Apr 8, 2002 | 02:08 PM
is there a difference between the 89-91 na and t2 rear 4.10 limited slip rear ends ? if so what and will an na rear work with a t2 drivetrain .. thanx
Old Apr 8, 2002 | 02:12 PM
mazdaspeed7's Avatar
mad scientist
N/a's have a 7" ring gear, TII's have an 8" ring gear. They also have different flanges. Its all or nothing, unless you custom make some stuff.
Old Apr 8, 2002 | 02:50 PM
WestJaxVert's Avatar
So is that the $100 vert?
Old Apr 8, 2002 | 08:24 PM
mad scientist
Yep, thats it. Heres more pics if you want to see.
I hope to be coming down to jax soon, but I dont know which car Ill be driving. The vert needs some work before I can drive it, like a new top, and fix the pass side window. Ill make sure Brian tells you when Im coming down, if I dont tell you.
Old Apr 8, 2002 | 08:36 PM
Icemark's Avatar
Re: difference in na/t2 4.10 limites slip rears ?
The only series 5 NA to come standard with a LSD was the GTUs and the gearing on that is 4.3 not the 4.1 like the T2. (although there is some rumor saying a few loaded with every option coupes in 91 had the 4.1 LSD rear ends as well- can't confirm that though.)
The T2 rear end was also designed with bigger halfshafts and a different driveshaft flange.
