Lookin to make around 700whp.. mod list recommendations?
Old Sep 18, 2007 | 06:15 PM
RotaryBred's Avatar
Lost You in the Rear View
Any changes i should make/add to make 700whp? Too many god damn options, lookin for some insight. Here's my list to purchase so far.
Power FC (already have)
3 3/4" or 4" turbo back exhaust
13b Bridgeport
Koyo Radiator
MSD wires
NGK 115 plugs
Triple pulley kit
Garrett GT4088
Greddy 3 row intercooler
3x MSD coils
3x MSD igntion
ACT extreme clutch
ACT Prolite Flywheel/counterwieght
4 x 1600cc injectors
Aeromotive Fuel Pressure Regulator
Fuel Lines/Fittings
block off plates
greddy elbow
Aeromotive eliminator Fuel Pump
3.5 Bar map sensor
Dual Stage Methanol/Water Inj.
Kaaz LSD
Chromoly Axels
SS oil metering lines
Old Sep 18, 2007 | 06:25 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
will a t88 support 700whp on a rotary?
Old Sep 18, 2007 | 06:30 PM
RotaryBred's Avatar
my mistake i switched it to a Garrett GT4088 but forgot to update my list
Old Sep 18, 2007 | 07:28 PM
ErnieT's Avatar
Living life 9 seconds at a time
You'll need a bigger turbo to start with, pinned motor, Guru e-shaft wouldnt be a bad idea, atleast a 4 bar map sensor, and a bridgeport wouldn't hurt either, and a BAD *** tuner. Good Luck!
Old Sep 18, 2007 | 07:33 PM
i dont think a gt4088 will cut it either, the gt42 family is probably where you want to start
do you have someoen building this? are they the same one's who are going to tune it? maby you should ask them rather than picking out parts
Old Sep 18, 2007 | 08:29 PM
RotaryBred's Avatar
bridgeport is already on the list. i'm plannin on havin it tuned at KDR when the time comes. Other than porting I will be building it myself over the winter through the end of next summer so i'm not in any rush. thanks for the advice. anymore would be appreciated. I wish there was a pro rotary tuner around here to help me out.
Old Sep 19, 2007 | 12:22 AM
RETed's Avatar
Originally Posted by RotaryBred
Garrett GT4088
To small.
You lucky you get 500 out of this turbo.
-Ted
Old Sep 19, 2007 | 04:02 AM
Trjackson's Avatar
You may as well scrap the power fc. Good luck with the build.
Jackson
Old Sep 19, 2007 | 06:00 AM
ErnieT's Avatar
Scrap your Power FC and SCRAP your tuner!
Old Sep 19, 2007 | 07:58 AM
Indian's Avatar
It wasn't me!!
wow ^^^^^^ hurtful words.
Old Sep 19, 2007 | 09:15 AM
RotaryBred's Avatar
loosing power FC. buying haltech
Old Sep 19, 2007 | 09:31 AM
Turbodriven's Avatar
A GT40 is to small. You'll need a GT42 or GT45F to make those #'s and leave yourself some room to grow as well.
Old Sep 19, 2007 | 10:40 AM
2a+RoN's Avatar
I saw a pic of a gt42 framed turbo running a gt45 comp wheel around here somewhere... That looked pretty damn sexy and would prolly get you around that power level. Motec is always another good ecu option to think about...
Old Sep 19, 2007 | 12:23 PM
sao1's Avatar
Steve Kan or Justin Nenni and VP import.
Old Sep 19, 2007 | 12:40 PM
Zero R's Avatar
Just in time to die
You'll want at least a 75mm inducer on the compressor to insure you'll get there. I would look at the autronic before you pull the trigger on the haltech. Ernie is running where you want to be with our 42R setup and Ray's Engine and tune. You'll either need a solid engine builder who knows what needs to be done to reach that power level or you'll wanna use the two piece E-shaft. It is a pretty high goal but not a hard one. There are more out there than you think
Old Sep 19, 2007 | 12:50 PM
I believe that is the same thing as the GT45F....but I could be wrong. I know it was posted on another forum with a picture of it and its in the link below. It appears to have the GT42 comp cover.
GT45F info and pic
Old Sep 19, 2007 | 12:52 PM
You not a Motec fan? I would like to see it versus the Haltech.
Old Sep 19, 2007 | 05:04 PM
ErnieT's Avatar
These are questions you need to ask your tuner. What would he rather you use. And make sure your tuner has built/tuned cars for the power range you want becuase the tuner you mentioned has NO experience in these power levels.
Old Sep 19, 2007 | 05:12 PM
Viking War Hammer's Avatar
*** Bless The USA
Exactly, he needs to spend more time asking his tuner questions instead of asking questions on a internet forums.
Old Sep 19, 2007 | 05:26 PM
Zero R's Avatar
Just in time to die
I have no issues with Motec. I said I prefer the autronic to the haltech.
Old Sep 19, 2007 | 10:15 PM
mr2foryou's Avatar
600+rwhp club member
Originally Posted by RETed
To small.
-Ted
'Tis not true. See sig. Mine is the GT4088R though. Which the GT4088 has a slightly bigger compressor. Mine is a 63.5mm where the non-BB version is a 64.7mm inducer.
But yes, as others have said, you would need to at least step up to a GT42(R) to achieve your goal of 700+rwhp.
Dee E.
Old Sep 19, 2007 | 11:36 PM
sk8world's Avatar
Chasing numbers
Take it to Ray and tell him your goals. Write him a check when you pick it up.
Old Sep 20, 2007 | 12:05 AM
Gorilla RE's Avatar
GorillaRaceEngineering.co
hahahahahahaha word!!
Old Sep 20, 2007 | 01:24 AM
RETed's Avatar
On pump gas?
I can usually find only 92 very easily.
-Ted
Old Sep 20, 2007 | 08:07 AM
Marcel Burkett's Avatar
Talking
So do I !!! and I happen to have a rotary friendly (split ignition capable) SM2 for sale !!
