13BT without turbo
Old Sep 18, 2007 | 01:13 PM
Surge's Avatar
Question 13BT without turbo
I saw a 13BT engine on sale and wondered if it would be feasible to modify to NA.
Does the 13BT have a lower compression ratio than the NA engines and if so what sort of power can one expect with the turbo removed?
Old Sep 21, 2007 | 08:43 PM
Boostmaniac's Avatar
8.5:1 for S4 and 9.0:1 for S5 (And FD I think).
With the turbo removed, expect it to run like ***.
That is all.
Old Sep 25, 2007 | 02:19 PM
diabolical1's Avatar
to answer your question, yes it is possible to modify it for N/A.
i noticed that you are in South Africa. i can't remember his screen-name, but there is a gentleman down in your part of the world that did a streetported 13B-T (even has video of it running on the highway) with what appears to be great results. if i recall, he runs an 50 mm IDA setup AND the stock turbo rotors. it might do you some good to search and see if you can contact him.
anyway, i'd say do it. you probably won't be disappointed. you can make good power with the turbo rotors - higher compression would be somewhat better, but they are not necessary.
Old Sep 25, 2007 | 02:34 PM
Surge's Avatar
Thanks for the replies.
If I can't get my hands on a decent NA motor I'll grab the turbo one instead. That way I can always add the turbo system when I have the time and money.
Old Sep 25, 2007 | 03:13 PM
what generation car is this engine going into?
i ask because i wasn't aware that you guys got the non-turbo motors over there and therefore would be a bit trickier to get your hands on one. also, if you're sure that you're going to want to turbocharge at a later date, then you'd be doing yourself a better service if you just get a 13B-T right off the bat. just an opinion ...
Old Sep 26, 2007 | 12:32 AM
Surge's Avatar
It's going into a VW Beetle which is why I'd like to use an NA motor at first.
Purchasing an EFI controller and doing all the turbo plumbing and tuning will easily triple the installation time and costs. I want to keep it simple to start with and then when I have the time and money I can play with the EFI and turbo setup.
I just wanted to know if it's feasible to run without the turbo so I can avoid having to purchase two motors.
Old Sep 26, 2007 | 03:09 AM
all you need is the T2 engine, a header and (if you really don't want to just go ahead and do the EFI, then) a carbie setup. you won't need 2 motors.
Old Sep 26, 2007 | 08:56 AM
karism's Avatar
Adolf Hitler Verfechter
surge:Go have a look in the "other Rotary" section.I have been busy building a Rotary beetle for the last year.You will find loads of details on the swop.
Alternatively,search under my username,info is all there.
13BT without the trubo is fine.This wont be my first engine using that config.
Karis
Ps:From South Africa as well.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
