failed turbo rebuilds. oil burning
Old Sep 17, 2007 | 07:24 PM
initial D is REAL!'s Avatar
I have recently been running a used engine with good compression. I got my stock s5 turbo rebuilt. My car was burning oil, so at first I questioned my used engine with good compression because my turbo had just been rebuilt. After meeting some people that had gone through the same shop, I was told a few bad stories or oil burning problems also.
I took it back already once. It looked dry everywhere, but when he took off the plate before u get to the seals, there was oil everywhere. So he got another seal and put it on. After driving 40 miles of no smoke, My car starts smoking like Cheech and Chong.
I have a 1/16" oil restricotr on it. My engine also has high oil pressure regulator mods. Im at about 70psi idle. You think that could have something to do with it?
1) He said the center housing section could be bad. What do you guys think?
Old Sep 17, 2007 | 11:31 PM
Turblown's Avatar
Turn up the boost
ring lands could be bad in the chra. Before the turbo was originally rebuild, if radial play was really bad and the thrust bearing was toast its usually a sign the chra is toast. If that was the case it shouldn't have been rebuilt.
Old Sep 18, 2007 | 08:25 PM
From what I remember, the thrust play was not very bad but the up and down motion was a little much.
What would I have to do to rebuild it to get the shaft play like new? Is it possible
So I took my turbo aback and I got word. He's having such bad luck rebuilding it, he is just going to stick the shaft back into one of the old turbos. Im really dissapionted because I paid 320 for the rebuild. And now it feels like I paid 320 for balancing. I dont know what to do
FD7KiD
15
Feb 26, 2021 10:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
FD7KiD
Aug 17, 2015 11:50 PM
pzr2
Aug 15, 2015 08:29 PM
