Weight of FD with 427c.i. CHEVY
Old Sep 16, 2007 | 12:02 PM
Naterry's Avatar
I corner weighted the car on Friday.
Would anyone like to guestimate the weight or weight distribution?
Here are a few pictures for reference:
HEAVY
Old Sep 16, 2007 | 12:15 PM
txturbogs's Avatar
I saw your whole thread at the V8rx7 forum. I must say I am very impressed, you've taken this far.
Hey, about a year ago I asked you have you have done to your front fenders cause I had an ls1 FD with the same front bumper, pettit flares, and you never replied. I was not going to copy it, I was just curious.
Congrats man....now lets eee how many flames you get, hehehe.
Old Sep 16, 2007 | 12:26 PM
redsuns_fd's Avatar
Wow, thats a beautiful setup you have there. What wheel/tire setup are you using? I guess I'll start with the weight guesstimates. Guessing with a stripped interior and no driver, 2700lbs. Thats really just a shot in the dark, I have nothing to base this guess on...
Old Sep 16, 2007 | 12:32 PM
trickshot's Avatar
With that torque and those worn rear tires I hope you're not driving in the rain.
(Or if you do, have someone video you from a chase car.)
Old Sep 16, 2007 | 12:52 PM
rotor88's Avatar
4230lbs. without driver.
Soul killer...
Old Sep 16, 2007 | 12:56 PM
rx7what's Avatar
Norcal RX7 Pimp
Those tires aren't that worn, thats what they look like. Actually they look pretty new.
I would also say some were in the 2,7XX range and 51/49 balance. Your car is sick, sick ,sick.
Old Sep 16, 2007 | 01:09 PM
Snyper's Avatar
Torque Monster
Soul killer...
hahah
Old Sep 16, 2007 | 01:18 PM
Andrew.'s Avatar
The end of an era
Forgeline 18x11 F, 18x12 R
315/30 PSC’s F, 345/30 PSC’s R
I'm guessing about 2575 with 49/51 weight dist. Nate- show 'em your full mod list!
Old Sep 16, 2007 | 01:52 PM
Naterry's Avatar
Sorry. I thought I replied to all those but looks like I missed one.
The front fenders started as Burnouts. I removed the spring/damper and cycled the front wheel/tire through all of the possible permutations. So full bump, full droop, lock to lock, etc, and trimmed all clashes. Once you have clearance a fender liner can be fabbed. I made mine out of sheet aluminum with 1/2" tubing for braces. this can probaby be done a number of different ways though.
You can see some if it here:
Cheers!
Nate
Old Sep 16, 2007 | 02:19 PM
trickshot's Avatar
A suitable epitaph for his tombstone if he drives that car with that setup on wet or slippery pavement.
Old Sep 16, 2007 | 02:43 PM
Naterry's Avatar
Hmm, that's strange, because I spent time at Carolina Motorsports Park in the wet, and set FTD. Must have been just luck??
Furthermore, I drove the car 60 miles each way (from Charlotte), each day, and it rained INCHES on the drive down. So yeah, be afraid, because I'll DIE if I drive this car in pouring rain on the way to the track to race in the wet and set FTD. Growing up in the northern rockies teaches you how to drive with limited traction. Go drive to the mountain a hundred times a year for a few years and get back to me.
Here's a picture from that weekend (on a dry moment) with my car next a rotary FD that broke down just trying to come watch the car run. (Hi Shawn!):
Next?
Old Sep 16, 2007 | 02:46 PM
txturbogs's Avatar
Thanks man I thought that maybe you thought I was going to copy it. Thanks again
Old Sep 16, 2007 | 03:56 PM
trickshot's Avatar
So you're admitting that car has limited traction? Not surprising. Thanks for making my point.
Old Sep 16, 2007 | 04:17 PM
jgonzales's Avatar
Avid Swapper
Great job man, it looks badass! It's kinda funny that the only negative thing said about it so far is that it has limited traction. LOL
Old Sep 16, 2007 | 04:31 PM
gnx7's Avatar
2700lbs and 48.5/51.5% weight distribution with a full tank of gas and no driver.
Sick setup Nate.
Trickshot- I got a ride in this car and it puts the power down well. With nearly 700hp at the flywheel on 91 octane... the car scoots for sure. In the lower gears if you want to... of course you can blow the tires off. But show me any RX-7 with this kind of power that couldn't.
Old Sep 16, 2007 | 05:23 PM
That Rx-7 kid's Avatar
car fanatic
That car is just ridiculous. What a piece of work that any car enthusiast should be proud to build or own. Nice man, real nice. Guess the weight? IDK maybe around 2600-2800 i have no clue haha
Old Sep 16, 2007 | 06:02 PM
frijolee's Avatar
the implications matter
My money is on 2850
Enough guessing... Tell us.
Old Sep 16, 2007 | 06:14 PM
Narfle's Avatar
Rx7 Wagon
Hey, douschebag. Those arent wet oriented tires to begin with, theyre not unreasonably worn by any standard, and stock fd's have traction issues in the rain.
Sweet car, btw.
Old Sep 16, 2007 | 06:32 PM
darksideperformance's Avatar
Bet its faster in the rain than most 7's. Nate does your car wander with the 315's up front? With my 285's on the street it has a mine of its own. Again, your car is Sex on wheels.
mike
Old Sep 16, 2007 | 09:55 PM
RX-Heven's Avatar
I'll blow it up real good
Nice to see you got the beast running.
The car is sweet and will be a force to be reckoned with on the track. I'm hoping you, Mark and I (if we ever get our cars together) can get out and spin a few laps together.
btw, does the LS7 weigh the same as the LS1?
Old Sep 16, 2007 | 10:58 PM
Brismo7's Avatar
6 Speed FC
hell, i'd expect the Ls7 to weigh a lil bit less than a Ls1. same small block design, but with 427 cubes drilled out, vs only 347 on the LS1...
Steve
Old Sep 16, 2007 | 11:30 PM
jimlab's Avatar
Super Snuggles
Stroker crankshafts weigh more, and so do larger diameter pistons. The cylinder sleeve thickness is still going to be comparable, but the sleeves are larger in diameter. A 427 short block will weigh a bit more than a 347, possibly as much as 5-15 lbs. depending on the components used.
Old Sep 17, 2007 | 12:04 AM
trickshot's Avatar
LOL! You're making all my points! You're saying exactly what I said, just using different language. (But you're getting quite defensive and had to engage in name calling.)
Old Sep 17, 2007 | 12:49 AM
Naterry's Avatar
Please, refresh my memory, what points are those again?
Old Sep 17, 2007 | 12:52 AM
Naterry's Avatar
Cheers!
Weight(s) linked:
http://www.v8rx7forum.com/v8-rx-7-bu...tml#post423783
