MSD 6 or CRANE HI-6?
Old Sep 10, 2007 | 04:55 PM
bop_rocco's Avatar
NOPSTNZ
I think i need to go with a msd or crane ignition box to help me out. At full boost and around 6 to 7k rpm i get a hesitation more noticeable in 3rd and 4th gear. should this solve my problem? I have 1300 cc secondaries, supra pump, power fc running 14lbs on stock turbos, not shure what else you all need to know. Also i see if i go with the crane hi-6 there is a couple diffrent part #'s available, whats the one i need thanks.
Old Sep 10, 2007 | 10:43 PM
diabolical1's Avatar
not convinced that either one of those is going to solve your problem.
what exhaust are you running?
what plugs?
in what condition are your ignition components? (coils, wires, etc.)
Old Sep 12, 2007 | 12:35 PM
bop_rocco's Avatar
NOPSTNZ
exhaust is racing beat dual tip for the moment, w/ 3" downpipe and midpipe with cat that has been gutted. as far as the plugs i think the stock 7's and 9's not shure though just got the car few months ago. and coils wires ect i think have around 25-30k miles on them.
Old Sep 13, 2007 | 09:28 AM
shock's Avatar
Hiiiiiiiiiiiiiiiii
GoooooD men! see ya sooooooon
Old Sep 13, 2007 | 09:37 AM
shock's Avatar
Hiiiiiiiiiiiiiiiii
Old Sep 13, 2007 | 09:45 AM
shock's Avatar
Hiiiiiiiiiiiiiiiii
Old Sep 13, 2007 | 12:02 PM
shock's Avatar
Hiiiiiiiiiiiiiiiii
Old Sep 14, 2007 | 05:43 AM
PDF's Avatar
PDF
Check the spark plugs! and if in doubt replace them!
Old Sep 14, 2007 | 05:58 AM
Latin270's Avatar
As far as your choices go, I had both and the CRANE HI-6 is a better made product and superior than the MSD in many ways!
Old Sep 16, 2007 | 02:37 PM
start by changing the plugs. if that doesn't fix things, then check your fuel mixtures in that RPM range. i'm not convinced that you'll NEED ignition amplfication at any power level the stock twins will produce, unless there is something wrong with the components themselves or the electrical path that feeds them.
dona1326cosprings7
Oct 29, 2015 06:47 AM
eplusz
15
Oct 7, 2015 04:04 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
