front suspension noise ?
Old Sep 4, 2007 | 12:17 PM
lexxs's Avatar
Hey all I got a ? for you guys.Suspension noise it when i make a quick sharp left turn there a noise coming from the front sound like wheel rubbing bot it's not.It happen only on left turn on right no noise. Any of you guys know what cost it or were to look for to fix this noise ?Thank
Old Sep 4, 2007 | 04:07 PM
Black1993rx7's Avatar
I'm having the same problem. The best i can figure is the camber is messed up so when turning quickly the car is running on the outside edge of the tire....
Old Sep 4, 2007 | 05:15 PM
MrNizzles's Avatar
NizzleMania Productions
I would probably jack the car up, or put it on jacks and check the wheel wobble .. and then, check the links underneath. Anyway to get the car up high, turn the wheels while looking underneath? If it doesn't make any sound then, it might be a weight-bearing issue, so maybe something strut/shock related?
Does it happen if you turn relatively slowly?
Old Sep 4, 2007 | 06:37 PM
No. The sound only occurs during quick cornering. Its especially noticeable going around round-abouts in excess and 35 mph. Any slower than that there is no "rubbing" noise.
Old Sep 4, 2007 | 09:48 PM
grimple1's Avatar
Turd Ferguson
might be a wheel bearing going bad?
Old Sep 6, 2007 | 08:54 AM
tsmysak1's Avatar
I have this same problem. Does the noise sound like a vibration at the same frequency as the engine speed? I am thinking it is a torque roll issue, since it is only left turn....
Anyone got any ideas?
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Snoopy FD
Dec 8, 2015 01:45 PM
GrossPolluter
Aug 15, 2015 10:32 PM
