grounding points
Old Sep 3, 2007 | 04:49 PM
turboIIrotary's Avatar
grounding points
i have bee making some grounds for my car and i was looking at some threads its shows people are making extra grounds coming from the negative battery to the engine but my battery is relocated to the trunk...where do you guys put your grounds at if you have relocated batteries?
Old Sep 3, 2007 | 08:29 PM
1QWIK7's Avatar
White chicks > *
I have my battery in my hatch and i have 3 ground wires off the negative there.
2 to the strut tower and 1 under the hatch carpet. Careful where you drill the hole for the ground point.
Also remember to scrap off the paint and make sure its bare metal.
Old Sep 4, 2007 | 11:31 AM
ArmitageGVR4's Avatar
ArmitageFD3S
I think I added an additional ground to the firewall, another to the alternator tensioner bracket, and also one to the transmission at the little service window. There are a couple writeups out there on the Internet on this topic as well, and one of them states that proper grounding of the ECU is the most important of all. I will have to revisit my setup and see if that has any effect on the dreaded 3k RPM hesitation.
Old Sep 4, 2007 | 05:25 PM
existanzrx7's Avatar
Just Boosting
Here is one I like!
https://www.rx7club.com/showthread.p...=ground+damian
Old Oct 11, 2007 | 01:35 AM
rx7goomba's Avatar
Old Oct 11, 2007 | 02:56 PM
Davin's Avatar
Back door, no babies...
Veteran: Navy
rotary resurrection also has a fairly good write up as well, check it out!
Old Oct 12, 2007 | 09:31 AM
Moejoe's Avatar
Maybe someone can answer this for me? I was told component video cable would be great for ground wire. I know there is a lot of difference between wire. But, I do not know one from the other. Does anyone REALLY know if this is an acceptable wire to use for grounding?
I want to do the grounding this weekend. I have quite a bit of component video cable. If I can use it, I will. If it's not going to work, I have to go shopping.
Thanks
Old Oct 12, 2007 | 10:20 AM
Moejoe's Avatar
The question above has been answered. It is not recommended to use component video cable at all.
rgordon1979
40
Mar 15, 2022 12:04 PM
ricardo.benin
Sep 22, 2015 12:06 PM
Donald Hampton
Sep 20, 2015 09:09 PM
rotor_veux
Sep 19, 2015 07:13 PM
