another rotary down for the count
Old Sep 2, 2007 | 09:36 AM
Maxrolla99's Avatar
vroom psshhhh vroom
iam at a total loss here. i have no clue what happened.
i was driving... and i went up to about 5grand then shifted. stopped for a stop sign and all of a sudden my cars idle is wack.. it starts stutting from about 400-1000. i give my friend chris a call who has an FD and he says it could be carbon build up and for me to put some gas in it and drive a lil longer to see what happens.
so i put a lil gas in it and drive for about 5 more mins. my friend is behind me in his car telling me when i come to a stop... i spit out very faint black smoke. nothing major but up close you kno its black. when im actually driving its white... not sure how white tho.. i cant see it out of the rear view.
this happened yesterday afternoon and im hearing everything from turbo seals to apex seals and its really starting to freak me out. has this happened to anyone else? can anyone help me out? its getting to me so bad i had a dream about the whole thing
Old Sep 2, 2007 | 09:47 AM
Mahjik's Avatar
Mr. Links
Start with:
1. Take a quick look around the engine to see if anything popped off
2. Do a compression check
Old Sep 2, 2007 | 09:49 AM
Maxrolla99's Avatar
vroom psshhhh vroom
me and my friend pulled over right away and checked the engine out and everything seems to be in place and no weird smells or nothing.
the compression check i'll have to find a place around here to have that done
Old Sep 2, 2007 | 10:06 AM
Mahjik's Avatar
Mr. Links
Just buy a $20 piston compression tester. It doesn't need to be exact. If your engine is blown, even a quick/cheapy test will show it. Here's some info:
http://www.rotaryresurrection.com/3r...ion_check.html
Old Sep 2, 2007 | 04:27 PM
grimple1's Avatar
Turd Ferguson
did any of the map sensor vaccuum lines pop off?
Old Sep 2, 2007 | 09:14 PM
Joe Geiman's Avatar
2turbos
If vacumn lines and associated look OK
Fouled sparkplug?
Check for a wet sparkplug and/or bad plugwire.
Old Sep 2, 2007 | 10:29 PM
rexhvn's Avatar
Rotary for life!
Fouled sparkplug?
+1 - check spark plugs/leads.
Old Sep 3, 2007 | 03:00 AM
RotaryResurrection's Avatar
compression check, then further troubleshooting if you pass. Number one rule of rotary engine troubleshooting.
Old Sep 3, 2007 | 11:42 AM
Alec's Avatar
Word from a vice man, get a compression check done before you start doing anything
Old Sep 3, 2007 | 01:01 PM
EricRyan's Avatar
Autocrossed. I got CONED!
This feels like another MAP sensor vacuum line thread to me...
Old Sep 3, 2007 | 01:21 PM
justturbo2's Avatar
Registered User
like everyone has said check for any visable problems hoses,vacuum lines. etc. then check compression good luck
Old Sep 3, 2007 | 01:23 PM
NTIMD8's Avatar
+1
Old Sep 3, 2007 | 01:57 PM
Oddly enough, on the HUNDREDS of FC's and FD's I have worked on and see, I have NEVER seen a map sensor hose come off. In fact, usually when it comes time to disconnect the hose, I have to pull and twist on it to the point that I am afraid the nipple is going to break off.
To hear you guys on this forum tell it, there are never any blown engine FD's, just FD's with map sensor vacuum hoses that fell off.
Old Sep 3, 2007 | 02:24 PM
jkstill's Avatar
Searching for 10th's
Well I have. It happened on mine just a few months after I bought it.
I had recently done a vacuum hose job on it, so it had been disconnected and reconnected. Once you take it off, it needs a zip tie, a clamp or a new hose that fits tighter.
Old Sep 3, 2007 | 02:45 PM
NTIMD8's Avatar
Happend to me as well, once while out for a late night cruise and once while autocrossing. I thought the motor blew but after some searching I found that the vacuum hose to the map had popped off. I have also read several other posts where people thought they blew the motor but turned out to be the hose popped off at the map (either right at the MAP, right after the filter or right before the filter). No one is saying the motor is not blown, just to look at something that may be the cause of the problem. If he is lucky it is just a hose.
Old Sep 3, 2007 | 03:15 PM
BuffDaddy915's Avatar
Tha ladies man
When Ive had problems with my fd that had a blown motor as an option, beyond a visual check tha first thing I do is a compression check.
Knock out tha compression test asap before u ruin all ur boxers shittin urself while pokin around everywhere else under tha hood. Rule it out so u know its sumthing little.
Old Sep 3, 2007 | 06:49 PM
Maxrolla99's Avatar
vroom psshhhh vroom
yep. its blown.
damn seals
i had a thought that came in my head to just sell the damn thing. ever since i bought it ive had to replace a bunch of **** that went out and do so much other **** to it just to keep everything in working order. but i think i just got ripped off on the buyers end. the seller didnt know who rebuilt the engine so i guess i shoulda been more cautious.
i cant sell it tho.. i love these cars. im gonna be optimistic about the situation, this time i'll kno atleast who rebuilt the motor and that its going to be done right. Rotary Resurrection i'll call ya in the spring!
Old Sep 3, 2007 | 06:58 PM
Hitokiri_Gensai's Avatar
RHD ftw!
ouchhh... blown rotary... that sucks man...
go with 3mm steel or if you can afford it, 3mm ceramics :P
Old Sep 3, 2007 | 07:28 PM
NTIMD8's Avatar
Crappy deal. Sorry it didnt turn out to be something simple.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
