Power FC Split Timing....?
Old Aug 28, 2007 | 04:23 PM
RotaryBred's Avatar
Lost You in the Rear View
Split Timing....?
i found a map online for split timing.. how come i can't find an adjustment map on the PFC?
Old Aug 28, 2007 | 04:32 PM
SPICcnmGT's Avatar
Because it's only accessable through the datalogit.
Old Aug 28, 2007 | 05:09 PM
RotaryBred's Avatar
bummer
Old Aug 28, 2007 | 11:52 PM
cewrx7r1's Avatar
Eye In The Sky
Originally Posted by RotaryBred
bummer
But the DL is a must have for the PFC. It allows many changes that do not required tuner experinece to make.
Old Aug 29, 2007 | 11:50 AM
RotaryBred's Avatar
yeah i plan on getting the DL.. just don't have it in hand right now LoL
Old Sep 2, 2007 | 10:34 AM
Ranzo's Avatar
just because you dont have datalogit dosen't mean you cant run a timing split.
You can do that with the commander. Set your leading timing to what you want and the trailing to what you want. The difference is the split.
Old Sep 3, 2007 | 03:21 PM
cewrx7r1's Avatar
Eye In The Sky
Originally Posted by Ranzo
just because you dont have datalogit dosen't mean you cant run a timing split. You can do that with the commander. Set your leading timing to what you want and the trailing to what you want. The difference is the split.
Way before the DL was available, we manually adjusted the 20X20 maps the hard way.
Zinraf
Oct 1, 2015 01:09 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
