Old 09-25-07, 12:02 AM   #51
Phantomkid
So i really didnt want to read all of this, so i got about half way through. I only really wanted to ask if your exhaust manifold racing beat had 2 bungs on each runner? if so are those for o2 seems kinda close, or are those for exhaust gas temp that would be pimp.. anyway now that ive spent like 30 min reading(im a slow reader) i have to add what little 2 sense i have. For the ports dont remove them you ruin airflow, probably why aaron doesnt like them. But pineapple racing does make redesigned sleeve i heard they where really nice, you may want to check them out. As for those talking about reversion i dont know if its muhc of a issue for a rotary we dont have valves that close, we also have a constant power stroke... im not a air dynamics engineer or anything nor can i spell for shit. But i know if we do have reversion it cant be as bad as a piston motor
The problem with a dry shot more on piston motors was the problem with getting equal distrubution of the nitrous. Unless your going full stand alone maybe even using those bunges for EGT and can tune amazing. your cure would be the wet shot or the direct port. If the direct port is angled it shouldnt build up to much on the walls.Thats gonna take some really nice fabvrications. but that would be your advantage of direct port the even distrubuation of nitrous. although theres always problem one jet doesnt spray. injectors clogs who knows. That leads me to another question what size injectors are you using. SOImeone mentioned using an Rtek i havnt looked at the 2.0 but the older ones were only designed for the turbo ECUs might have to try something else.
Some hopefully helpful ideas...
if i was running nitrous i would play it safe, nitrous is like any other power adder. Providing more oxygen. Nitrous does not make power the more fuel it can burn does. So upgrade your fuel system if your shotting for some high numbers. For safty you might want to get some sorth of ECU that can handle the nitrous. you should use a full throttle switch, so nitrous isnt activated at lower RPMs, I always wanted to also hook up a fuel pressure switch may be a little pricing but if the fuels not there, then you dont have nitrous saving you from a blown motor.
o as for propane it yields a higher octane rating. i think 130, maybe 120 but you need more of it then fuel and whereas gas wieghs in at 8pounds a gallon propane is 25 something to think about. personally i think just stick with that gas stuff itll make it less complicated. plus i think ever thinks your trying to push like 500hp, but i dont think you even rebuilt that motor so maybe just 75 extra ponies from the nitrous
Phantomkid is offline   Reply With Quote
Old 09-25-07, 02:10 AM   #52
Dltreezan
Posts* 277,892
Dltreezan's Avatar
Send a message via AIM to Dltreezan Send a message via MSN to Dltreezan Send a message via Yahoo to Dltreezan
ok this is for Scathcart. I read through almost all of this thread. When I get unbroke, if ever I want to do a pretty decent sized streetport on my s5 na, and want to run nitrous when I feel like having fun or need to dust someone. I want to run a 100 shot, so let me get this straight according to you.
This is what I want to do.
s5 streetport, 6 puck clutch with lightened flywheel, exhuast bolt ons. 100 shot nitrous.
So I should do this according to you if I understand right.
Run a dry shot before the TB, and porting the TB is a good idea. Also use an Rtek to keep my timing good for when I strictly want to run the nitrous it will make the changes accordingly and will only do so when the 5/6 ports are open correct? Then I will be good? what elso should I need?
Dltreezan is offline   Reply With Quote
Old 09-25-07, 09:32 AM   #53
The Shaolin
Canned. I got CORNED!
Send a message via AIM to The Shaolin
The experts finally agree on something Single fogger it is, then.
Which FPR should I be looking at?
The RB header came off a fully prepped SCCA car. I had two bungs tapped in, one for the stock o2 sensor and one for EGT. There is a bung tapped where the two pipes join together for a wideband sensor.
Stock. Rtek makes an S4 N/A ecu now. Looks pretty fancy
No I didn't. I really didn't want to spend any more money then I had to on an N/A setup. This should hopefully yield a running RX for another summer...it keeps me wrenching and planning...and it should keep me happy and busy for awhile
Thanks everyone for the input. I'll be home again this weekend. Hopefully should be able to get the rear calipers rebuilt and re-installed and have working brakes. Maybe I'll pull the fuel pump out and see how it looks.
2000 Saturn SC1 (blown up, in storage)
1995 Saturn SC2 (because I wasn't taking up enough parking spots...)
2000 VW Jetta TDi
The Shaolin is offline   Reply With Quote
Old 09-25-07, 07:55 PM   #54
anewconvert
Dl: the consensus is to stay away from a dry shot. A wet shot would be more advisable. Also the RTEK will not control nitrous, so you set your timing for nitrous and run down a few hp when you aren't running it. Or go to a full standalone. If you go full standalone you could tune the car to control the nitrous. In other words when you activate the nitrous the computer will automatically drop timing and adjust fueling to compensate for the added oxygen. You could then choose to run a dry shot. This route would likely result in you needing a bigger fuel pump, larger injectors and lots of time on a dyno.
BC
anewconvert is offline   Reply With Quote
Old 09-25-07, 11:39 PM   #55
Phantomkid
Thats nice EGT is nice i would see can the rtek run a wideband to the ecu as a narrow band. therefore eliminating the need for the narrow band all together and you can runn 2 egt's one for each rotor. instead of only seeing what one rotor is doing you can see both and compare.. think about it.....mmmm
Old 09-26-07, 12:12 AM   #56
anewconvert
I know the RTEK can log wideband. If you can find a wideband with a controller that will sim a narrowband then you could do both out of one O2 sensor. Finding a wideband and controller that will sim a narrowband 0-1v shouldnt be hard.
BC
Old 09-26-07, 10:58 AM   #57
PDViper77
HAHA V8
PDViper77's Avatar
Trader Score: (9)
Send a message via AIM to PDViper77
Nice thread. Lots of info in this one. I will be doing an ITB setup on a big SP or BP and a DP nitrous setup with a 150 shot. Hope you get good results.
1993 BB Base - GT47R 20B Coming Soon
Ford 8.8" IRS Cobra w/ 4.33s Rearend
562 whp @ 24psi w/ GT42R Half-Bridge, Tuned by STEVE KAN
11.209 @ 131.93 MPH - 24 PSI
2000 Honda Prelude SH w/ Giggle Juice - Daily Driver
2007 Suzuki GSXR750 142 WHP - My other Baby
PDViper77 is offline   Reply With Quote
Old 09-26-07, 09:03 PM   #58
The Shaolin
BC
Can't I run a nitrous and an N/A tune? I hope there's more than one timing map...just sold my SAFC...
I think I finally figured out how I'm going to wire all this.
Green are vacuum lines
3500 RPM -
Window switch grounds relay for nitrous, activating it.
Window switch grounds relay for air pump, turning it on and opening the aux ports.
5500 RPM -
Using the RTEK, activate the EGR solenoid or other such solenoid which opens air line to VDI, activating it. A bleeder valve will need to be rigged up somewhere in here.
8600 RPM -
Window switch breaks ground to relays, disarming nitrous and turning off the air pump.
The aux port bypass switch will ground the relay and manually override the window switch to turn on the air pump at all time. This way, the aux ports will function normally, but I can manually open them when spraying or beating on the car. (not that I plan on spraying below 3500 anyways, this is just an extra safety measure)
2000 VW Jetta TDi
Old 09-27-07, 01:13 AM   #59
anewconvert
If you keep the shot below 75 (100 if you are ballsy) then you should be fine running stock timing maps. If (when) you get bored at 75 then you should start pulling timing. Scath's write up suggests 1* per 25 hp, I have also read 1* per 50. 1* per 25 is safer though
BC
Old 09-27-07, 01:29 AM   #60
The Shaolin
Perhaps I shouldn't have been so quick to sell the SAFC. I'm really looking forward to using the Rtek though. I've heard the SAFC actually may retard timing with the way it modifies the AFL readings.
2000 VW Jetta TDi
Old 09-27-07, 02:20 AM   #61
rosey
rosey's Avatar
Send a message via AIM to rosey
Looks good, a few things to consider...
The manual override switch isn't really necessary, the reason I thought that may have been a good idea is because too much stuff seemed to be happening at once and a failure the 5th and 6th port actuating circuit could mean big problems. I think you would be better off using a mircoswitch on the actuator so if the air pump fails or the vacuum line leaks, or the the ports fail to open for any reason, the kit just won't arm.
The walbro and 5/16" lines will support plenty of power, I have personally made over 500whp with just a walbro running through the stock lines at 58psi with an estimated brake specific fuel consumption of about 0.5lbs.
With the Rtek pulling timing, I would work your way up to a 150shot, might be a good idea to follow scathcarts advice and run a strait elbow off the TB...a backfire is definitely a possibility with this setup, so you'll probably want to take every precaution possible.
Can't resist...
False. Distribution of nitrous will be best with a dry hit, in fact off the bat it will often be as good or better than a direct port in regards to having a consistent AFR between cylinders. The direct port does hold the advantage of having an individual fuel jet for each cylinder, so if certain cylinders are running lean its a jet change away from fixing it.
Would you rather change a few values on your laptop or shut the car off, get out, find a 7/16" and 3/8" open end, reach into a hot ass engine bay, undo the fuel hose at the nozzle, pull the jet out, drop it on the ground, reach in though the engine bay to try to grab the jet, burn yourself on the exhaust, get on your hands and knees and try to kick the jet out so you can reach it, pick it up, grab a bag full of jets and hold them up one by one trying to read the sizes of them stamped on the side, after going through all of them realize you don't have the one you need, push the car off the dyno, go order a jet a pay $5+shipping, wait 3 days...shit fedex doesn't deliver on sundays, make that 4 days....go to slip the jet into the nozzle, drop it on the ground....
You'll need the bigger fuel pump either way, and upgrading injectors isn't a big deal, you can even offset some of the cost because you don't need a fuel solenoid. I understand that because of limited EMS options on these cars a dry shot isn't going to be easy to setup, but don't bash the dry hit...it is the future of nitrous.
rosey is offline   Reply With Quote
Old 09-27-07, 07:41 AM   #62
RotaMan99
Actually we do have need to take into consideration about the reversion wave. Your right we don't have valves, but we do have ports, and those ports do close when the side of the rotor passes over them which will cause the highspeed airflow in the intake manifold to slam up against the rotor and bounce back up the intake manifold. Mazda took this into consideration when they built the S4 intake manitold, only the primary port runner took the reversion wave into consideration. Mazda then decided to go a step further with the S5 and design the VDI which changes the timing of the reversion wave and allows the timing to be MUCH shorter which will cause the wave to be stronger.
I can't say it would be "as bad" but probubly more effective in a rotary then a piston engine as long as the intake manifold is build with the reversion wave in mind.
I have heard a lot of success stories with using N20 on a rotary. Not sure if the reversion wave would cause the N20 to itemize in the air stream very well or not, im leaning more toward not...
I read somewhere that the OP wasn't sure how to make the ports and nitrous work together and though there must have been a reason for why Mazda opens the ports later. Its due to the intake velocity. Personally I would only operate the N20 when the velocity is higher, above 4000rpm. After the Aux ports. Im pretty sure mazda did the same thinking for the secondaries. With the secondaires spraying fuel in the intake runners up high, intake velocity needs to be there to help itemize the fuel with the air intake. Placing them to close may have hurt top end performance since there may not have been enough time for the fuel to itemize in the air stream as well as if they were placed further down the intake.
Having no experience with N20 I can only add little suggestions. I would place the nozzel(s) around where the secondary injectors are. A quick bend and straight down to the ports and you shouldn't have to worry about anything on the walls. You shouldn't have to anyways is you activate the N20 / Fuel at higher rpms where velocity is highest.
Using a throttle switch, or using the S5 full range with a "simple voltage switch" will not allow you to switch the N20 on at specific RPMs. Only a RPM switch will do that.
Now you can use both, throttle and rpm so that the N20 is only active during 80-100% throttle at a specific rpm.
Originally Posted by The Shaolin
3500 RPM -
Why use a window switch for the Aux ports? You trying to have a over rev safety? I wouldn't go above 8000 at all unless your engine was built for high rpms, which I highly doubt it is. There for, get rid of the window switch idea and use a straight MSD rpm switch.
Do not operate the AUX ports below 3800. This is a stupid idea. Intake velocity will go to nothing and you will loose low end. If you operate the N20 at those low rpms, I doubt you will get the full benefit of the N20. Im going to go out on a lim and say maybe even risk detonation?
Using the same air pump is a bad idea. when the VDI kicks in, there could be a substainsul pressure drop and allow the AUX to close a bit and then have both the VDI and AUX open SLOWLY. You need a pretty good air pump if your going to go that route.
I have had the idea of using a 1/4 gallon tank with a small air compressor that would charge the tank to about 6-10 psi and hook the VDI and AUX to the tank using solenoids to activate them and this would cause the ports top open more quickly and not have to worry about air pumps kicking on and possibly overheating and shutting down while operating for long periods like my 2 lumbar air pumps do after 3-5 minutes.
doesn't the Rtek 2.0 have maps for fuel and timing?
The Community Service Manual and Modification Manual
The rotary engine is full of win.
came out as:
The rotary engine victory is complete.
RotaMan99 is offline   Reply With Quote
Old 09-27-07, 10:15 AM   #63
rosey
rosey's Avatar
AFAIK any changes in timing made by an SAFC would be completely indirect and therefore pretty much make it into a crapshoot. An SAFC is a half assed way of tuning, you'll be much happier using the Rtek and actually being able to change the values in the computer, instead of trying to figure out the best way to trick it into getting you what you want.
Old 09-27-07, 10:26 AM   #64
PDViper77
HAHA V8
PDViper77's Avatar
Trader Score: (9)
Don't settle for a weak 75 shot. Go big so I can use this for reference when I spray mine. Good Luck!!!
Old 09-27-07, 02:11 PM   #65
anewconvert
PD, pm scathcart for referense to higher shots. He has topped out at about 400.
Look forward to ITBs and juice by the way. If I stay in the RX7 game long enough that would be a route I would like to go down.
BC
Old 09-27-07, 06:28 PM   #66
The Shaolin
Thank you, everyone, for the feedback on the VDI/Aux ports. This is going to be a giant pain in the ass.
I had taken the pressure drop into consideration, but I was hoping that by giving the aux ports 8 PSI or so, they would snap open, and then 4 psi would still hold them when the vdi opens.
I don't know how else to do it, short of wiring up two air pumps and two RPM switches...trying to keep it simple, but I guess I'll do what it takes to make this work.
2000 VW Jetta TDi
Old 09-28-07, 02:13 AM   #67
scathcart
I wish I was driving!
Send a message via AIM to scathcart
I'd go wet. Retard timing to ~22 degrees advance, 12 degrees split. N/A WOT should be 26-27* advance.
I have no experience with the RTEK. I prefer standalones.
scathcart is offline   Reply With Quote
Old 09-28-07, 02:32 AM   #68
scathcart
Can't resist....
I'd rather change mechanical jets. Atomization is improved by forcing fuel out through the fogger jet... 950 psi will do that. For equal nitrous jettings, properly optimized, a wet shot will make more power for this reason every time.
As for your scenario...
I'd much rather grab my shiny -AN wrenches, pop the hood, undo each fogger nozzle, grab my organizer filled with jets, and have at 'er. Don't need to worry about dropping shit or burning myself as my mom didn't drink when she was pregnant with me.
Here's my scenario for you:
You've decided to grow a nut and drop your pussy 75 shot for a 150 shot. You pop the hood and change the nitrous jets. You now need to retune the car on nitrous... and hopefully you don't max out your injector duty cycles. Shit... now you need new fuel injectors and have to retune the entire car. Then, you decide to grow another nut, and rejet to a 250 shot. Again, you need to retune. *yawn*. With wet, you can establish a baseline jet ratio that gives you your desired AFR, and then just use that same ratio as you move up in power shots. One run to make sure all is good and you're one your way... might need to pull out a fuel jet size here or there as you move up so you don't get too rich. No nerdy laptop, no multiple runs to tune the thing properly... just jet and go.
Old 09-28-07, 02:36 AM   #69
scathcart
BC
With these engines, its pretty much gotta be 1* per 25 degrees, or around 5 per 100. A 200 shot on a 160 rwhp N/A should be pulling about 10 degrees advance, so somewhere around 16-18* depending on how the EGT's look. The advance is not surprisingly similar to the timing map of an equal power producing turbo engine.
Old 09-28-07, 02:38 AM   #70
scathcart
3500 RPM -
5500 RPM -
8600 RPM -
If you don't mind, I'll draw you up a better schematic a little later, likely early next week. I can post the modified turbo manifold /PP set-up then. I'll be at the shop all this weekend, so I'll garb some decent shots.
Old 09-28-07, 11:55 AM   #71
The Shaolin
No, I don't mind at all...I'm definitely willing to figure out a better way to do this.
2000 VW Jetta TDi
Old 09-29-07, 02:37 AM   #72
rosey
rosey's Avatar
Originally Posted by scathcart View Post
Can't resist....
Your saying a nozzle mounted before the throttle body is going to atomize fuel better then the fuel injectors at the port? hmmm sorry, physics is working against you there. I don't know if you have any proof that you have made more power in the past with all other factors being equal, but even if that were true, you should jet to the power you want to make, period.
My setup is firing though a hotwire maf, so a once the tune is setup properly I can up the shot size and the maf will compensate for the larger shot without me having to touch anything. If not using a maf you will have to make adjustments to the nitrous fueling map when you change the nitrous jet, you can scale the fuel accordingly and tweak it a little if you need to, then save that tune and use it whenever you switch to that sized shot...sorry if you don't have the means to tune your car properly, but I do.
You should size your injectors to the amount of power you want to make, a little forward thinking solves that "problem".
Guess what these all have in common...
http://videos.streetfire.net/Player....1BD5FBDD33&p=0
http://videos.streetfire.net/player....5-0004B59456E9
http://i161.photobucket.com/albums/t...sBackfire3.jpg
http://www.ls1tech.com/forums/attach...chmentid=44532
Give up? They were all caused by wet kits backfiring. Let me know if you'd like me to find more examples, because there are plenty. Ever experienced this in a car you've worked on?
If you find an engine that was damaged by a properly set up dry hit, it is a tuning mistake or the internals of the engine were simply not strong enough. Even if the solenoid stuck open on a setup going through the maf you'd still be alright because the maf would still compensate. Ever had a fuel solenoid stick open or fail to open? Blown engine. Ever had a nitrous solenoid stick open on a wet kit? Blown engine.
If you seriously think wet kits are a good idea on a modern efi vehicle - not just a compromise, you still have a lot to learn...guess experience isn't everything.
I'll stick with my nerdy laptops and dry hits and you can keep hoping your "balls" are big enough to spray because your awesome wet nitrous kit is capable of starting your car on fire
Old 09-29-07, 07:18 AM   #73
RotaMan99
Thread is interesting.
Not know much about this, why do the wet shots like to backfire? Bad placement?\
I never thought about running dry through the maf. Think it would work with a flapper/cone type AFM?
came out as:
Old 09-29-07, 03:42 PM   #74
anewconvert
they tend to backfire beucase you are spraying fuel through a manifold that isnt designed to flow liquid through it. The fuel hits a flat spot and falls out of suspension, or hits a sharp corner, and then gets lit off.
Boom.
BC
Old 09-29-07, 05:37 PM   #75
Phantomkid
rosey what are you using to tune? The nitrous on the MAF how accurate is that being that nitrous is very cold i understand the MAF would in turn be tricking thinking more air is going to the engine(which in a wierd way...is) but i just wondering how accurate that could be. Does the MAF get dirty, how often do you have to clean it? i would think that the wire would crack after all it is a heated wire and then your shotting ice cold nitrous the drastic change in temperature doesnt effect the MAF? sorry for all the question im just wondering how your set up works you seem to know alot and i would like to also build a safe powerful set up.
13b, aux, lumbar, port
HTML code is On
Build-up thread - (pics of your build up or your blown engine) GregFD3S 3rd Generation Specific (1993-2002) 19 02-06-07 11:53 PM
Nitrous car vid. Got nitrous experience? Please post here. Doc Holiday Rotary Car Performance 7 12-26-05 10:51 AM
Confuse to build a 13b to turbo with 500hp or to swap to a 13bt and build it to 500 h FC3sinfiniIII 2nd Generation Specific (1986-1992) 26 12-13-05 12:45 PM
