Rate my Boost
Old Aug 26, 2007 | 07:25 PM
SammyD's Avatar
Rate my Boost
Ok so got rid of the Z4 M Coupe and got another FD yesterday.
It's a '93 R1 with 63k miles, pretty mint.
Mods are cat back exhaust and aftermarket air filter set up. Dyno'd at 260 RWHP! Mechanic said that those were the only mods and that just a 'pill' (?) was probably being used as the boost was not spiking at all and was at acceptable levels.
So here's the deal - sometime she boost real hard, sometimes she doesn't. I had this a bit with my old car. It's like if you get on the gas hard at like 3k rpm she'll boost nicely. But get on the gas after say 5k and even in 3rd she sounds like she's leaking boost or something. It's like if the first turbo doesn't get to spool before the change-over then she doesn't want to know.
Any ideas? Also should I come off the pill (arf arf) and just go with another Power FC?
Thanks all...
Old Aug 26, 2007 | 07:45 PM
bajaman's Avatar
Constant threat
I've noticed this phenomena too. Usually what happens is I will be in 2nd gear (shift lever in 'L', automatic), revving pretty high around 65 mph or so, and when I stomp it hard it simply has no boost, but if I shift it into 'S' the boost hits HARD as the RPM drops. At the same time, if I am seeing it is not wanting to boost, I can simply back off the throttle a bit and then nail it again and it will boost perfect.
Like you I think it is simply venting the boost thru the CRV.
Old Aug 26, 2007 | 08:00 PM
SammyD's Avatar
whats a crv?
Old Aug 26, 2007 | 08:10 PM
MADDSLOW's Avatar
17 second FD
charge relief valve
Old Aug 26, 2007 | 08:52 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
This issue has been discussed before. A cause and solution was posted...
https://www.rx7club.com/forum/showthread.php?t=372894
https://www.rx7club.com/forum/showthread.php?t=341534
http://rx7.voodoobox.net/howto/solen...oid_check.html
Old Aug 26, 2007 | 09:51 PM
SammyD's Avatar
Thanks!
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Bauer778
Nov 4, 2015 04:42 PM
blackball7
34
Sep 16, 2015 10:10 AM
