Front Wheel Bearing
Old Aug 25, 2007 | 04:28 PM
Bri's Avatar
Bri
Front Wheel Bearing
Hi,
I'm looking for the part number for a front wheel bearing for a 1999 RX7, can anyone help?
Thanks,
Brian.
Old Aug 25, 2007 | 05:14 PM
ObliqueFD's Avatar
I believe you have to buy the entire wheel hub and cannot buy just the bearing. If it is the same as the ones from '93 - '95, then it is GA5S2615XA. MSRP is $144.81. You might be able to get it cheaper at Malloy.
Autozone sells an after market wheel hub from Timken for $66.99. I recently purchased mine there and have yet to install it. I can get some pictures for you if you'd like.
Old Aug 25, 2007 | 07:12 PM
Bri's Avatar
Bri
Wheel Bearing
I was told you can replace the bearing only, but if you have pics, that would be great. Will have a look at Autozone.
Old Aug 25, 2007 | 09:13 PM
ObliqueFD's Avatar
Old Aug 26, 2007 | 03:02 AM
gracer7-rx7's Avatar
needs more track time
someone had posted them either in this section or the Suspension section. I think ptrhahn might have posted in that thread also. try searching.
Old Aug 29, 2007 | 07:52 AM
Bri's Avatar
Bri
TIMKEN Wheel Hub Assy
Hi ObliqueFD,
Would there be any chance you could find out how much it would cost you, if you were to ship this hub to Dublin, Ireland.
Brian.
fidelity101
13
Aug 31, 2015 07:47 PM
RaY358
Aug 19, 2015 11:44 PM
Marty RE
Aug 17, 2015 09:36 AM
