Clunking Noise in rear
Old Aug 24, 2007 | 03:04 AM
anderdick88's Avatar
need help finding a clunking noise in the rear driver side, replaced all the busing with the Derlin bushing kit still no help, any advice would be help full THANKS
Old Aug 24, 2007 | 04:03 AM
rexhvn's Avatar
Rotary for life!
Pillowballs?
Old Aug 24, 2007 | 05:28 AM
YOUWSH's Avatar
Pillowballs!!
Just replaced mine and it went away.
Take both Lower Control Arms off and I'm almost certain there will be play in them. When you move them just with your fingers you will hear a click click metal sound so imagine in a real driving situation where you brake hard or accelerate, that sound is your clunks.
Old Aug 28, 2007 | 09:23 PM
YOUWSH's Avatar
I still get a little creaking sound in the rear especially going up driveways when one of the rear wheel is higher than the other. Its the lock and you need to adjust this by lowering it a little. The theory behind this is it will pull the hatch tighter to the car so theres less room for it to rattle.
And like gmonsen said try and shake your hatch struts and if there's play you'll hear a sound to go with it. I replace one of mine as it was really loose. Another thing you might want to check is the rear wiper motor. There are a few bolts which can come loose so try tightening them.
Old Aug 28, 2007 | 09:34 PM
turboIIrotary's Avatar
mine make a clunking noise every time i shift cant figure it out either
Old Aug 28, 2007 | 10:31 PM
v8huntr's Avatar
how much are pillow *****?
Old Aug 28, 2007 | 10:37 PM
Moejoe's Avatar
$345 I think.
Old Aug 28, 2007 | 11:39 PM
thanks alot guys ill try replacing the pillow *****
Old Aug 29, 2007 | 12:11 AM
v8huntr's Avatar
what about front same sound from front of the car?
Old Aug 29, 2007 | 04:08 AM
Nope no sound coming from the front
Old Aug 29, 2007 | 04:24 PM
FD3Smaniac's Avatar
slurpee
sorry did u say u replaced the differential mount bushings?
autoxer
21
May 22, 2019 04:07 PM
msilvia
28
Apr 14, 2016 12:58 PM
Michael Mansour
Aug 18, 2015 03:13 AM
