PFC :injector pulse timing correction
Old Aug 5, 2007 | 06:20 AM
jbust's Avatar
13BREW
Hi guys, i have a question about injector lag time correction, Im currently running a 850cc primary and 1600cc Secondaries injectors. On the PFC manual, they have a formula to use to correct the 1 minute injector volume by this: Q-Sc > Q-Pr
i figured out the primaries ( 850cc = 0.77 - 550cc = 0.73 = 0.04 ms) Since i dont have datalogit, i could only go up to 1500cc on the secondary, im trying to figure out what the formula stands for.. so i can get the correct number for the 1500cc. can anyone help? thanks.
john
Old Aug 5, 2007 | 02:15 PM
cewrx7r1's Avatar
Eye In The Sky
Only for the primaries do you have a size ratio to enter.
550/new size = %. 550/850 = 64.7
Both have a change in lag value:
New Injector Lag - Stock injector Lag = lag change.
The PC manual explains this very very well.
Since you do not have a DL, trying to setup 1600 as 1500 will cause the engine to run way too rich. Buy/borrow a DL to setup 1600 correctly.
THIS SHOULD BE ON THE PFC FORUM, WHY DID YOU NOT DO THAT?
Old Aug 5, 2007 | 10:33 PM
jbust's Avatar
13BREW
oh, i thought i posted in pfc forum ;/ this will be probably moved, but anyway, thanks for another valuable info again you been a very good help member on this forum. like everybody else that started with rotaries, im new to it and learning all i need to. again thanks.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
diabolical1
30
Jan 30, 2016 05:50 AM
The Shaolin
Sep 14, 2015 07:50 PM
incubuseva
14
Sep 3, 2015 12:37 PM
torky007
Aug 17, 2015 05:14 PM
