RX7 Rotor Bearins on Renisis E-Shaft?
Old Jul 29, 2007 | 10:11 PM
farberio's Avatar
NASA-MW ST4
Can you use S4/S5/S6 Rotor Bearings on the Renisis E-shaft?
Or do you have to use Renisis Bearings, and if you do do RX8 Rotor bearings fit in S4/S4/S6 rotors?
Old Jul 30, 2007 | 12:00 AM
Box_Man's Avatar
I hate drum brakes
I think they're all the same.
Old Jul 30, 2007 | 11:13 AM
R.P.M.'s Avatar
Likes to swear....alot
As long as the clearances are right, there should be no problem.
I built an 89 Turbo motor using RX-8 stationary gears and e-shaft with the 89 Turbo rotors and bearings.
Old Jul 31, 2007 | 10:10 AM
BDC's Avatar
BDC
BDC Motorsports
Did you have any issue w/ the lack of sealing o-ring on the Rx8 rear stationary gear?
B
Old Aug 1, 2007 | 06:29 AM
funklove's Avatar
In rotor we trust!
I use it on 13B-RE
Old Aug 1, 2007 | 07:42 AM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
B
the motor he's talking about is mine (well, he built one like that for me anyways :P)
and still has no oil leaks at the sealing o-ring.. we just put RTV there and it seemed to work fine.
Old Aug 2, 2007 | 03:33 PM
R.P.M.'s Avatar
Yeah, you have to port match the oil feed hole on the rear stat gear to line up with the oil filter feed in the rear iron, then put a nice bead of high temp silicon around the base of the stat gear where the o-ring normally goes.
Never had a problem so far, and I've put together quite a few of them like this.
Old Aug 2, 2007 | 10:33 PM
bugeyebug's Avatar
Dumb question: what is the advantage of using the Renesis stationary gear over the original one? Stronger? Lighter? Or??
-Bug
Old Aug 2, 2007 | 11:02 PM
farberio's Avatar
NASA-MW ST4
-Bug
Better suited for high RPM.
Old Aug 2, 2007 | 11:09 PM
riceburner1r2001's Avatar
man y do u need rtv. if its built right then u shouldnt need it
Old Aug 2, 2007 | 11:29 PM
R.P.M.'s Avatar
Its not built in, thats the problem.
The older stationary gears have a small o-ring around the base of them where they mount to the rear iron. The new Renisis stat gear doesn't have anything, just a machined flat surface, so RTV sealant of some kind is needed with use of the older irons.
Old Aug 3, 2007 | 12:49 AM
j200pruf's Avatar
RIP Icemark
Could you just machine the grove into the rx8 stat gears? Seems like that would be pretty easy.
Old Aug 3, 2007 | 12:53 AM
R.P.M.'s Avatar
Sure but not everyone has access to a lathe to do such a thing. Its definatly possible tho.
Old Aug 3, 2007 | 10:29 PM
Kyrasis6's Avatar
MazdaTruckin.com Founder
Did you have to rebalance the engines with the RX-8 eshaft? I wasn't going to worry about it because I could do it at work but I got fired on Friday, so no longer have personal access to the machinery.
Old Aug 7, 2007 | 09:42 AM
Rotary-Celica's Avatar
-Bug
Price they are cheap.....er
set screws and windowed bearing, hardened gear did I say price.
heres some info on the eshaft
RX-8 Shaft
These shafts are .6lbs. lighter than the earlier 13B shafts. The main journal diameters are approximately one-half thou smaller, and there is a one-half thou taper in the rear main journal.
Old Aug 7, 2007 | 11:43 AM
R.P.M.'s Avatar
Nope, no rebalancing.
Old Aug 7, 2007 | 05:13 PM
BLUE TII's Avatar
Rotary Motoring
Yeah, RX-8 e-shaft has a tapered rear journal like the MFR race e-shafts so you don't have to taper clearance the rear half of the rear stat gear bearing for high rpm duty like when using earlier standard e-shafts.
Old Sep 2, 2007 | 07:27 PM
Kyrasis6's Avatar
When I measured my RX-8 eshaft it had the same taper on both the front and rear journal.
Old Sep 2, 2007 | 11:50 PM
user 893453465346's Avatar
Red Pill Dealer
Very interesting..........and logical when you think about it.
86glxNA
Aug 18, 2015 03:33 PM
rx7jocke
Aug 15, 2015 03:36 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
