Single Turbo so don't use BUR9EQ?
Old Jul 6, 2007 | 08:33 AM
onesick7's Avatar
Ok so I just completed my single swap and am headed to the local parts shop for some new plugs. I was told I need colder then BUR9EQ plugs but I wasn't sure what I should go to though. Could anyone with a similier setup let me know what type of plugs your running? Thanks guys.
Setup:
GT35/40R
1300/550 INjectors
Walbro 255lph pump
FMIC
3" HKS Exhaust
Old Jul 6, 2007 | 08:47 AM
turbodrx7's Avatar
PURIST
BR10eix, you have to have a special socket for get them in and out though. Kgparts sells the sockets, lots of single turbo guys run these plugs.
-Austin
Old Jul 6, 2007 | 08:49 AM
hondahater's Avatar
spending too much money..
I've heard the iex's are not good. lots of people are going br10egv.
Old Jul 6, 2007 | 08:54 AM
onesick7's Avatar
Do you have to have a special socket for br10egv?
Old Jul 6, 2007 | 10:21 AM
charlies7's Avatar
3rd rotors a charm
I just run 9's all around and haven't had any problems...
Old Jul 6, 2007 | 10:38 AM
hondahater's Avatar
not sure about the socket but I think you do. Don't worry about it though, some places will sell those sockets for 60 bucks but you can find them for 20. or you could just grind down one of your own if you have a bench grinder.
Old Jul 6, 2007 | 10:44 AM
onesick7's Avatar
oh man if Charlie is doing so am I! <3 <3 hehe thanks guys
Old Jul 6, 2007 | 10:48 AM
hondahater's Avatar
I know I will not use a 9 in my car. Of course I'm shooting for 500+rwhp. I'll prolly end up going br11egv.
Old Jul 6, 2007 | 10:50 AM
charlies7's Avatar
3rd rotors a charm
True, since ill be only hoping for 400whp . 9's all around should be fine
Old Jul 6, 2007 | 10:54 AM
hondahater's Avatar
yeah I believe it all has to do with your hp goal really.
Old Jul 6, 2007 | 11:50 AM
villision 1revin7's Avatar
I have 9s all around 440hp
Old Jul 6, 2007 | 11:57 AM
onesick7's Avatar
Yea I am going for 400-420 so I will try these 9's all around
Old Jul 6, 2007 | 12:55 PM
Rotor Nut.
i had break up with 9's all around. i guess everyone is different. i also use a different plug. this plug was listed on the forum years ago and has worked great for me its a 10* and they also come in 11* ngk v power r5671a-10. worked great on my 427whp setup no break up at all. also they cost 1.80 a plug and you can use the 5/8 socket which is nice. since they are so cheap i change them every 2k miles.
Old Jul 6, 2007 | 01:17 PM
dhahlen's Avatar
FD Under Construction =P
I did 9's all around, had the gapped plugs and the special socket. Did 500hp on these no problem.
Old Jul 6, 2007 | 01:19 PM
dhahlen's Avatar
I suppose if charlie became a flaming homosexual, you would too correct?
Ohh wait.. too late!!!
Haha, just playin... well, not about charlie.
Old Jul 6, 2007 | 01:21 PM
Wargasm's Avatar
Weird Cat Man
For 400 rwhp, I run the stocker 9's in the LEADING positions, and BR10EIX in the trailing positions and I get a nice color on them and no break up.
The BR10EIX do require a thin wall socket which typically runs 50+ dollars and can be hard to find at the local store. I just took a standard cheap-o 3 dollar Craftsman socket and carefully used my bench grinder to grind down part of the tip (till it fits). Don't grind down more than you have to, and don't try to overtighten the plugs and it should work ok.
Old Jul 6, 2007 | 01:49 PM
cewrx7r1's Avatar
Eye In The Sky
There aren't any BR#EGV plugs. They are non resistor and are B#EGVs.
The iridiums are resistor thus you have BR#EIX.
If not available locally: http://www.sparkplugs.com/
Old Jul 6, 2007 | 02:16 PM
hondahater's Avatar
yeah thats where I get my plugs from and thanks, I knew I was saying it wrong.
Old Jul 10, 2007 | 04:08 PM
Arrow
Setup:
GT35/40R
1300/550 INjectors
Walbro 255lph pump
FMIC
3" HKS Exhaust
Chris, if you're going to keep posting, how about you update this debacle of a thread?
https://www.rx7club.com/bad-fugly-members-185/issues-me-seller-chitownr1-midwestbest-mwb-drifted7-tyrant-tt-615307/page7/
Old Jul 10, 2007 | 06:44 PM
Zebb's Avatar
Use "EQP" and not "EQ". The EQ doesent last for long...
Old Jul 10, 2007 | 07:03 PM
rotorbrain's Avatar
fart on a friends head!!!
the "eqp" lasts just as long as the "eq". . . dont waste your money.
Old Jul 10, 2007 | 07:11 PM
classicauto's Avatar
Crash Auto?Fix Auto.
Setup:
GT35/40R
1300/550 INjectors
Walbro 255lph pump
FMIC
3" HKS Exhaust
Fu**ing lowlife P.O.S.
_____________________
I think you should run stock plugs in a not so stock location - your scam artist ***!!
Old Jul 10, 2007 | 08:32 PM
hondahater's Avatar
lol, the drama that is the rx7club.......better than a soap operah
So who has the b11egv plugs? When does 11's become nessasary?
Old Jul 12, 2007 | 12:37 PM
Jay7 Nyc's Avatar
Good info, I'd like to try these ngk v power r5671a-10 plugs. Anyone else use these NGK r5671a-10 plugs on there FD?
Old Jul 18, 2007 | 06:56 AM
DelSlow's Avatar
Hot Dicken's Cider
I checked at autozone for the r5671a-10 and they had them in stock, but what do I gap the single prong to? Never used plugs in my car that needed gapped before...
