help me to choose single turbo
Old Jun 27, 2007 | 07:38 AM
rx7italy's Avatar
Arrow help me to choose single turbo
i want to make single turbo conversion....
but i drive a single FD...i don't like it
maybe because have high torque at high rpm...
what is the best turbo to make a high torque at low-mid rpm?
for ex. Apexi D1 Fd have 50 kg with APEX RX6 TCW76-P27(Boost set @ 1.0kg/cm2)
or JIC rx-8 (13B engine) have a T04Z A/R .60....had big torque at 4000 rpm...
Old Jun 27, 2007 | 09:27 AM
FC3S.USD's Avatar
Where is my Life ?
I think you already pointed out what you need.
Also what power level are you looking for ? assuming the norm 400 hp at 1 bar .
Where power comes into play is not just the turbo, but exhaust and IC setup and tune.
But taking into account turbos, go with with a standard and not too big of a AR example.
TO4S with .70 front cover and T4 .96 dividided ( if exists ) .
GT35R same specs as above
a T61
even the to4Z as you stated with a smaller exhaust side ( .84 divided or .96 ) and a good DP and exhaust.
Or if on budget a TO4R
Old Jun 27, 2007 | 12:33 PM
rx7italy's Avatar
if i do a single conversion 500+ hp is the target....
my exhaust is 3"
my i/c is hks type R 600 mm x 296 mm x 106 mm
Old Jun 27, 2007 | 12:46 PM
rx7italy's Avatar
Shot at 2007-06-27
this is a snapshot of best motoring vol.27....
...the JIC rx-8 have 530 hp with a T04Z 0.60 A/R...
i've the same intercooler and 3" exhaust by hks
Old Jun 27, 2007 | 04:55 PM
dregg100's Avatar
at what boost?^^
Old Jun 27, 2007 | 07:17 PM
FC3S.USD's Avatar
Where is my Life ?
I believe it was 1.6 bar.
well for 500hp you will need a bigger turbo and or higher boost. you get to choose.
bigger turbo= laggier
higher boost = higher octance gas or AI .
If its a track car, might as well go with a 4" Downpipe , exhaust also wouldnt hurt and get a TO4Z or a GT4094R make sure divided turbine housing and a good divided manifold .
I have no experience with the rest. so Hopefully others will post in.
Maybe try posting again when this thread goes down , with a Title like:
Want to make 500 hp for a track car , heres what I got .
Old Jun 28, 2007 | 06:52 AM
rx7italy's Avatar
tnx for idea.....
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
