GT42 oil feed fitting size?
Old Jun 26, 2007 | 11:27 AM
DelSlow's Avatar
Hot Dicken's Cider
I'm at work right now, but I need to get the fitting ordered for this weekend. Anyone know what size the fitting is for a non-bb GT42? Can't seem to find it anywhere, not even on the Garrett website...
Thanks
Old Jun 26, 2007 | 12:55 PM
Zero R's Avatar
Just in time to die
I use a flange and gasket, I tap the flange to whatever size I need. Usually 1/8npt
-S-
Old Jun 26, 2007 | 09:35 PM
DelSlow's Avatar
Hot Dicken's Cider
Well, I don't have enough time to make the flange right now, but I can get the fitting by this weekend. Anyone know the thread size?
Old Jun 27, 2007 | 01:27 PM
CarbonR1's Avatar
It is difficult to say since there are a lot of different GT42's and they have different oil inlet threads.
If you can manage to give me a part number on the center housing, I can find the thread for you, otherwise it'd be a stab in the dark.
Kevin
Old Jun 27, 2007 | 01:36 PM
Marcel Burkett's Avatar
Try www.atpturbo.com.
Old Jun 27, 2007 | 03:34 PM
Zero R's Avatar
Just in time to die
IF it is a tapped CHRA your fitting size will be 1/8npt. If you need the fitting I have the fitting here.
-S-
Old Jun 27, 2007 | 03:37 PM
finnicky7's Avatar
26.55 psi T04Z Monster
You can get 1/8 npt at any good parts store. The stainless brakeline feeds are the same as the AN adapters.
Old Jun 27, 2007 | 03:54 PM
DelSlow's Avatar
Hot Dicken's Cider
I don't think it's a 1/8NPT. I have a 12mm (by 1.25 or 1.5, can't remember) and it fits, but it seems abnormally loose. It's definatly a straight thread, not a taper.
Old Jun 27, 2007 | 06:24 PM
Don't those turbos use restrictors?
Frisky Arab
13
Aug 18, 2015 05:30 PM
