How good of a pump?
Old Jun 25, 2007 | 05:29 PM
futureshock's Avatar
How good of a pump?
Good Day to all.
Walbro 255lph INTANK PUMP.
Is anyone running this intank pump with more than 400hp in their motor. I looking to buy an intank pump just need some direction. My HP goal at the moment is 400+........Can this intank pump support that amount of HP......Thank you for any help.
Old Jun 25, 2007 | 07:17 PM
fd rotar tt's Avatar
i would consider using a different pump they are very problematic, and are prone to failure. if anything i would use two of them for a intank setup.
Old Jun 25, 2007 | 07:35 PM
fritts's Avatar
Mad Man
I would never use a dual pump setup. You are better off killing a single pump and having the car die than killing one pump of a dual pump setup running lean and going kabooom. Others on the forum have had luck with the boost a pumps on the walbros for higher horsepower.
Old Jun 25, 2007 | 07:42 PM
i personally dont use a dual pump setup but have seen many successful setups that have, but they are usually the denso pumps. you are completely correct fritts, thats why i run a very large external fuel pump.
Old Jun 25, 2007 | 10:22 PM
nik's Avatar
nik
I've seen a car dyno 407 whp with a single walbro and no sign of running out(others have done more i'm sure). I've run dual walbros for over a year and no problems, even run them dry a few times.
However, I have also heard of failures on rare occasions.
Old Jun 25, 2007 | 10:47 PM
mr2foryou's Avatar
600+rwhp club member
439rwhp on a single pump with no problems. Now that I'm going for more power, I have stepped up to 2 Walbros.
Dee E.
Old Jun 26, 2007 | 07:45 AM
Thank you all for your help
Leaning towards getting the Walbro and give it a try. Should I get Two pumps for safety reasons
Old Jun 26, 2007 | 07:51 AM
hondahater's Avatar
spending too much money..
Dee E.
and some run a bit more (490rwhp) with the pump. So take what you will from these two hp numbers and get the pump(s) that you need for the hp you are looking for.
Old Jun 26, 2007 | 08:42 AM
Thank You again for all the help
Old Jun 26, 2007 | 09:17 AM
Donn Hecht's Avatar
1 BAD 7
From what I noticed a lot of people are using Walboro with good results.
I myself would rather go with an Aeromotive fuel pump they used to be called SX.
Those pumps I have seen in some serious high horse power setups.
I believe they support up to one thousand horsepower. The Aeromotive Fuel regulators are good as well. Theres something about the looks and size of the pump that make me skeptical about there performance. Also the price, I mean come on what kind of quality can you expect from a fuel pump at $100.00 or less. You get what you pay for.
Old Jun 26, 2007 | 09:48 AM
I had an SX pump but it went bad. I would try the Walbro for now and see if its any good.
Wolf_
Aug 11, 2015 04:23 PM
