contour/mystique rims on a first gen?
Old Mar 30, 2002 | 10:49 PM
whofarzed's Avatar
what kind of rims do the 95-99 Contour or Mystique have? I was looking at a catalog that had Ford racing performance parts wheels for this year Contour or Mystique and it says "SVT Contour RWD fits 95-99 Contour and Mystique, available in: 16x6.5 with a bolt cirlce of
4x110mm"
I thought Contours were front wheel drive? Is the SVT a diff model (I do not know much about American cars).
Does someone know if the stock Contour/Mystique rims would fit on my rx-7 (if they are nice)? I thought only Mazda made the odd bolt pattern on the 7 and earlier rotaries and 626?
Old Mar 30, 2002 | 10:53 PM
V8kilr's Avatar
hmmm sounds interesting,
the contours even the svts are front wheel drive,
but i dont see any problem with using the rims if the fit,
im pretty sure the only diference in front wheel and rear wheel rims is that the front wheel rims are made stronger.
Old Mar 30, 2002 | 11:24 PM
whofarzed's Avatar
just looked at a Contour forum. The Contours/Mystiques have a 4x108mm (I remember someone posting something here about it before) bolt pattern. The stock SVT wheels (according to someone on that forum) has a offset of 49.5. What is the offset of my car? would they fit? They look pretty nice. (except for the snake in the middle of the rim)
Old Mar 31, 2002 | 12:13 AM
V8kilr's Avatar
would 4x108 fit on 4x110?
is that what your asking?
i dont think so,
i wouldnt try it.
Old Mar 31, 2002 | 12:15 AM
V8kilr's Avatar
then again do you have access to a bridgport?
im sure it would be easy to make a 2mm adjustment
Old Mar 31, 2002 | 01:23 AM
moremazda's Avatar
Gone Race'n
Those wheels will stick about an inch outside the fender. The offset for the 4x110 is 25-28mm.
Old Mar 31, 2002 | 02:22 AM
V8kilr's Avatar
so they do make a 4x110 ?
thats insane,
they would work perfect with a wide body kit if they stick out a little,
im gonna have to check em out.
Old Mar 31, 2002 | 08:43 AM
peejay's Avatar
Old [Sch|F]ool
They are 4x108, not 4x110.
I would not use them, then again I'm pretty strange, I like when my wheels stay ON the car
demetlaw
Oct 2, 2015 06:22 PM
NickNac113
13
Oct 1, 2015 09:25 PM
