Old 06-23-07, 08:14 PM   #1
tigermack
CPS Motorsport
tigermack's Avatar
Send a message via AIM to tigermack
My car won't idle correctly and dies if I let go off the gas pedal.
So as titled stated... my car won't stay idle... it idles at 500 and it will slowly dies. I give it a little gas then it'd stay up a bit and repeat the same.
What happened was...
I had a fuel leak from the fuel hose going to the carb... so I replaced that and it's working fine. I was running low on gas... and my driveway is not a straight road so the gas was probably not feeding in to stay idle so it died on my driveway... I poured in gas... tried to start it and it wouldn't start even I let the fuel pump on for a bit. So I tried to start it again and again... and one of the starter cable was burnt... there were smoke coming out so I finally gave up. Next day, I got that fixed, started the car up and it started fine but the car sounded a little rich... it ran well though so I went to the gas station to fill in some gas. The car wouldn't start back up after I got it filled up... it was odd... so I left it there until the next morning and fix it with my bro... first thing we checked was to see if the spark plugs were wet and they were, kinda burnt too... but we flushed the float boat and got the plugs dry and clean so we can get the car home... it started up... at first the car didn't sound like it's going to die... so I thought it's fine until I reach up to an intersection... my car started to idle at 500 rpm and the car was jerking when it's not even moving, so I got it home and it died on me right at the moment when I was fully stopped. Took out the plugs and its burnt again... so I just ordered new plugs... had to wait 3-4 days so I got Autolite instead today. The car started up but I had to jump it... then after the choke .... the car started to want to die again at 500 RPM... I don't know why this is happening... it was running fine until the car died cause it ran out of gas.
Me, my bro, and my friend thought about maybe it's the cap and rotor? But they are like new condition... spark plugs wire are fine, my battery is about 6 months old... we can't think of anything else...
Can you guys please tell me why this is happening??? Thanks!
1982 GS (Auto-X/Track)
tigermack is offline   Reply With Quote
Old 06-23-07, 09:49 PM   #2
aussiesmg
Thunder from downunder
aussiesmg's Avatar
Send a message via ICQ to aussiesmg
Does it miss at constant throttle or deceleration...if so search "shutter valve" its a very easy bypass fix.
Old age isn't so bad when you consider the alternative.
aussiesmg is offline   Reply With Quote
Old 06-24-07, 12:41 AM   #3
trochoid
Old Fart Young at Heart
trochoid's Avatar
Send a message via MSN to trochoid
Sounds like when the tank got empty, the ful pump sucked up the juck at the bottom of the tank. Check/replace your fuel filter.
trochoid is offline   Reply With Quote
Old 06-24-07, 02:53 AM   #4
tigermack
CPS Motorsport
tigermack's Avatar
Besides those... what else can it be?
Old 06-24-07, 02:55 AM   #5
tigermack
CPS Motorsport
tigermack's Avatar
I have a YAW carb by the way... if that helps or not... what is the shutter valve?
Old 06-25-07, 12:28 PM   #6
tigermack
CPS Motorsport
tigermack's Avatar
Bump!
Old 06-25-07, 06:17 PM   #7
aussiesmg
aussiesmg's Avatar
Its a device to increase economy when off the throttle, do a search...
Old 06-26-07, 12:23 PM   #8
tigermack
CPS Motorsport
tigermack's Avatar
The rat nest is removed... so what's the shutter valve? Is there still one when the rat nest is removed? I can't find anything on the device for increase economy... =\
Old 06-27-07, 08:54 PM   #9
tigermack
CPS Motorsport
tigermack's Avatar
I replaced the fuel filters... both of them... still doing the same thing... what's next? Should I try the idle screw?
Old 06-27-07, 09:19 PM   #10
firstgen689
firstgen689's Avatar
a truck i had it was throtle body and it would flood it self out mayb a jet or something is stuck wide open
firstgen689 is offline   Reply With Quote
Old 06-27-07, 10:31 PM   #11
tigermack
CPS Motorsport
tigermack's Avatar
I was looking for the idle screws... but I can't... I wanna try to play with those and see what I can come out with... it's a YAW carb... just to let you know... I was wondering if the shutter valve is there? The rat nest is gone.
Old 06-28-07, 03:20 AM   #12
boyee
keep it original!!
boyee's Avatar
im not too familiar with different carbs and rats nest but i had idle issues and i had my air control valve changed and that solved everything. i thought i saw a mixture screw in the third pic, the one with the spring on it
boyee is offline   Reply With Quote
Old 06-28-07, 12:08 PM   #13
tigermack
CPS Motorsport
tigermack's Avatar
Ok... I found the idle speed screw last night and played with it to the correct RPM. It worked! I thought the car is going to be all good, so I took it out for a spin... it ran pretty smooth for a mile or so then when I was coming to a stop... the car started to idle very low again... I tried very hard to give it gas to pump the engine back up... it didn't work and it died. We had to push the car back home... now I have no idea what can happen? I checked the float boat and it seems to be filled again! I don't know why... is it time to check the needle and seat now or... what should I do before that? Something might be more simple?
Old 07-16-07, 10:52 PM   #14
Sterling
Nikki-Modder Rex-Rodder
Sterling's Avatar
Location: Trying to convince some clown not to put a Holley 600 on his 12a.
Send a message via AIM to Sterling Send a message via MSN to Sterling Send a message via Yahoo to Sterling
What fuel pressure are you running?
Have you changed the fuel filter, as asked priviously?
Have you tested for vacuum leaks?
Your valve is gone from the manifold, which is good, but how thick is that cover? Is it sealed with Hylomar, or something similar, or not? The plate looks thin to me.
I think there's a combination of problems here. First one is that your idle speed was too low, which you've fixed.
You REALLY need to get a Haynes manual for your car. It will tell you all the troubleshooting basics.
VE [ (Displacement x Maximum RPMs) / 1728 ] + 15% = all the cfm your NA engine could ever use. Just do the math.
Choosing a carburetor that exceeds your engines maximum cfm requirements will only result in crappy low end performance.
Sterling is offline   Reply With Quote
Old 07-17-07, 12:28 AM   #15
tigermack
CPS Motorsport
tigermack's Avatar
I am running 2.5psi for the fuel pressure, i replaced both of the fuel filters, and there is no vaccum leak (i sprayed the exterior of the carb, but the engine didn't bog at all). I have the haynes manual and i think i tried everything they suggested for this problem.
car, dies, filling, gas, give, idle, idling, integra, move, rendezvous, rx7, start, tank, whens, wont
Help: Engine Starts then Dies Unless Gas Pedal Is Pressed umli5 2nd Generation Specific (1986-1992) 6 03-25-06 12:34 AM
so my car does ther thing where it starts and dies, gas pedal doesnt do anything k-rok 2nd Generation Specific (1986-1992) 29 10-25-05 11:28 PM
gas pedal is pressed, it dies Myc1972 1st Generation Specific (1979-1985) 14 08-25-05 10:04 PM
help..cant get 86T2 to idle correctly Touge fc33 2nd Generation Specific (1986-1992) 1 05-19-03 10:18 AM
very low idle, then it dies out???/ smg944 2nd Generation Specific (1986-1992) 6 05-17-03 11:23 AM
