Technical word for rotor shape
Old Jun 10, 2007 | 06:22 PM
matula11's Avatar
What is the technical name of the shape of the rotor in a rotary engine. I know its a stupid question, just wondering. Thanks
Old Jun 11, 2007 | 12:41 AM
Boostmaniac's Avatar
My first impulse was to go with triangle, but I know there is a much larger word that describes it much better.
Old Jun 11, 2007 | 01:21 AM
Evil Aviator's Avatar
Rotorhead
The inside of the rotor housing is a peritrochoid shape, and the rotor is shaped to fit inside of it. I guess the rotor shape is best described as a Reuleaux triangle. Hopefully some of the advanced math folks on the forum can come up with a more accurate description.
Old Jun 11, 2007 | 10:28 AM
PercentSevenC's Avatar
I need a new user title
Rotors are similar to, but not exactly, Reuleaux triangles. They are more flattened on the faces than a true Reuleaux triangle.
Old Jun 11, 2007 | 10:41 AM
monkhommey's Avatar
if you want to know about geometry then this is interesting reading.
http://www.personal.utulsa.edu/~kenn...n/chapter7.pdf
this paper gives some interesting insight into eccentricity ratio and some other cool things. evil aviator.. i believe that is an accurate description of the shape.
Old Jun 11, 2007 | 12:57 PM
diabolical1's Avatar
i don't know if this is very helpful, but you might want to see what organic chemists have to say about the shape of cyclopropane. i remember when i was taking orgo, the stress of the bond made it curve like a rotor. worth a shot, eh?
oh and monkhommey, thanks for that paper.
Old Jun 11, 2007 | 01:07 PM
ikari899's Avatar
engineer wanabe
http://en.wikipedia.org/wiki/Reuleaux_triangle
http://en.wikipedia.org/wiki/Epitrochoid
Old Jun 11, 2007 | 01:58 PM
Blake's Avatar
The rotor shape is called a 3-flanked Hypotrochoid, which is the inner envelope of a 2-lobe Peritrochoid. This according to Rotary Engine by Kenichi Yamamoto.
Old Jun 13, 2007 | 12:49 AM
Blake wins.
Old Jun 25, 2007 | 10:34 PM
ROTARYROCKET7's Avatar
trochoid rotors spinning in an epitrochoid curve.
Old Jun 27, 2007 | 07:24 PM
micah's Avatar
Winter sucks
Big.....Words...... Hurting...... Brain.........
Why not just call it an inflated triangle.
Edit: better yet, a triangle.... WITH BOOST!
Old Jun 27, 2007 | 08:22 PM
patman's Avatar
Resident Know-it-All
i would say the description most likely to be understood by your friends is: "its like one of thsoe 3d doritos"
vipernicus42
Mar 7, 2016 04:57 AM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
