Tubemiter: Excellent Program To Make Tube/Pipe Miter/Notch Templates
Old Jun 10, 2007 | 10:54 AM
Aaron Cake's Avatar
Engine, Not Motor
I was making some wastegate runners yesterday and needed to join one piece of pipe to another at an angle. Lacking a tubing notcher normally I would do the grind and fit thing until the notch was done. Figuring that someone must have templates on the Internet for various tube/pipe joining scenarios I did some searching and found an excellent little program called Tubmiter. Tubmiter lets you input the diameter of the pipe/tube, the wall thickness, the diameter of the tube/pipe you are joining to and the angle of the joint. It then spits out a paper template you can print and wrap around you tube/pipe to mark your cut. Using this software anyone with almost any type of grinding tool can make close-fitting miters on almost any size of tube.
Free download:
http://www.ozhpv.org.au/shed/tubemiter.htm
Old Jun 10, 2007 | 03:38 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
neat. thanks Aaron.
howard coleman
Old Jun 11, 2007 | 11:22 AM
diabolical1's Avatar
thanks, Aaron. might come in handy someday.
Microtech
30
Apr 23, 2016 06:37 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
