how to make steering better
Old Jun 8, 2007 | 08:17 PM
rx7 freak's Avatar
Newbie
Unhappy how to make steering better
my steering sucks cuz i thought that rx7 had power sterring but i guess not but its all ruff how do i make my steering better
Old Jun 8, 2007 | 08:31 PM
Manntis's Avatar
add to cart
Tighten the steering box adjustment screw or install a new steering box
Old Jun 8, 2007 | 08:52 PM
HEYTOYOTAGUY's Avatar
where is this screw you speak of? (pics?)
Old Jun 8, 2007 | 09:38 PM
notveryhappyjack's Avatar
1 bar boost
replace tie rods inner and outter, then align it. should be tight again
Old Jun 8, 2007 | 10:22 PM
Kentetsu's Avatar
A search would have brought you to this thread right here....
https://www.rx7club.com/showthread.p...steering+grind
Old Jun 9, 2007 | 08:30 PM
trochoid's Avatar
Old Fart Young at Heart
Tightening up the steering system is done in this order, ONLY.
Check/Replace: Idler arm, tie rods and adjusting sleeves, ball joints, pitman arm, wheel bearings. After all those components are confirmed good or replaced, then adjust/replace the steering sector, not/never before.
If the other components are worn/loose and one attempts to take the steering slop out by adjusting the sector only, it is usually over adjusted and that will cause binding and accelerated wear of the sector. Been there, done that. Replacing all of the other steering components is 1/2 the price of a new sector.
Old Jun 9, 2007 | 09:09 PM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
dont tighten the nut on the steering rack too tight (the one you need to use a hammer and chisel on), I think that is the one that made my steering wheel űber stiff.
matty
Jan 18, 2020 10:39 AM
mr.veilsidewankel
20B Forum
Aug 20, 2015 03:20 PM
