what size rims does everyone run?
Old Jun 8, 2007 | 12:01 PM
jwilson's Avatar
im looking to get some new rims cause i hate the ones on my FD now...they are 18x7.5 in the front and 18x8.5 in the back....im lookin to get somethin with a good size lip on the and i dont know much about offsets and whatnot....i was thinkin about goin 10 in wide in the back? would it fit?
what are all you guys runnin on your FD? pics would be nice? thanks
Old Jun 8, 2007 | 12:05 PM
rynberg's Avatar
Impossible to answer your question, do some searching around!
*what is your real budget for just wheels?
*what kind of styles do you like (5-spoke, mesh, etc)
*what do you use the car for?
*stock body? suspension mods?
Old Jun 8, 2007 | 12:13 PM
jwilson's Avatar
ok cool...well i love meshes and 5 spokes...so one of those options...the car is just a car to drive around on weekends and to work....or whenever i feel..nothin crazy...the budget doesnt matter...i dont have a budget on it. i will do some searching...thanks oh yeah and stock body...no suspension...yet that is...in a month or so should be getting a suspension setup
Old Jun 8, 2007 | 12:46 PM
rynberg's Avatar
No budget is not a realistic answer....unless you can really afford and are willing to spend $6k on a set of wheels.
Old Jun 8, 2007 | 12:55 PM
peachykeenwight's Avatar
marky
Wait on the wheels until you get the suspension, you'll probably have more options once you have the suspension all done. Coilovers?
Old Jun 8, 2007 | 01:54 PM
jwilson's Avatar
well true my budget would probably be around 2,500 or a lil more...
yeah i plan on doing some coilovers...searchin the whole suspension as we speek..lol
Old Jun 8, 2007 | 02:02 PM
Mahjik's Avatar
Mr. Links
Check here for wheels: http://www.autornd.com/
IMO, 17" is still the sweet spot for the RX7. If you are looking for 10" in the rear (regardless of diameter), I would suggest an offset of +45 to +50.
I currently have two sets of aftermarket wheels:
1. 17x9 +43 (all 4)
2. 17x9F & 17x10R (+47 all 4)
Old Jun 8, 2007 | 08:58 PM
jwilson's Avatar
1. 17x9 +43 (all 4)
any pics? thanks
Old Jun 8, 2007 | 09:03 PM
Mahjik's Avatar
Mr. Links
Attached is the 17x9 +43
Old Jun 8, 2007 | 09:05 PM
Mahjik's Avatar
Mr. Links
Old picture of the front:
Old Jun 9, 2007 | 02:21 AM
jwilson's Avatar
awesome..thanks man..looks good..
ok so now is it the more posative the offset the bigger the lip will be?
say i have a +35 in the front and +45 in the rear will the rear have a lot larger lip?
Old Jun 9, 2007 | 04:05 AM
akaRobbyStyle's Avatar
no, lower the number on offsets, the bigger the lip/dish... unless the number has a - in front of it which makes it less than zero... remember the number line in math? works like that. its all relatively simple once you get into it.
Old Jun 9, 2007 | 06:42 AM
Mahjik's Avatar
Mr. Links
It mostly depends on the wheel style and build (i.e. 1, 2 or 3 piece). In general, the lower the offset the more lip the wheel can have. The rear of the car can take a lower offset than the front. So in general if you wanted to run a staggered type of setup, you would have a "higher" offset up front than the rear.
Lower offset means the wheel is moved further out towards the fender. Higher offset means into the center of the car more. The stock FD wheels are a +50 offset for reference.
Old Jun 9, 2007 | 09:06 AM
purerx7's Avatar
Registered User
not necessarily, on my advan sienna generation II's I have a 5 inch lip on a +46 offset.
FD7KiD
15
Feb 26, 2021 10:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
