How long do your guy's motor last
Old Jun 6, 2007 | 04:40 PM
binary89's Avatar
This is a question for all you single turbo guys pushing in excess of 450hp. How long do your motors last.
Old Jun 6, 2007 | 09:03 PM
dhahlen's Avatar
FD Under Construction =P
First one - 2 days
second one - 2 weeks
third one - 2 months
fourth one - hopefully 2 years, haha.
It was all due to stupidity from either tuning or engine build or my reckless *** running into ****.
However, I know a few ppl running 450+ hp and their **** has been solid for months and tons of drag runs.... they are using pump + AI though. Runs solid as hell for most of them.
Old Jun 6, 2007 | 09:12 PM
Busted7's Avatar
Will work for horsepower
dhahlen im pulling for you ya man. Seems like youve been through it.
Old Jun 7, 2007 | 12:28 AM
Directfreak's Avatar
I am a Jeeper Now.
3 Years and Counting... Wastegate Spring is 15 lbs, So that is the minimum I can run. The car is always running 18+psi. (Pump Gas). No Water, No Alcohol, just regular 93 gas from Mobil.
My engine last made 492rwhp at 20 psi, when the turbo ran out of breath,
and can't keep up with the volumetric efficiency of the engine at redline.
My engine isn't even that impressive, It's a small streetport
that was built by someone else.
But, the combination of parts and great fuel system make up for a lot.
The number one reason I am still on the same engine, while rotary 'acquaintences' are are on their 3rd, 4th, or even 5+ engine's...
There's nothing like a ******* great tuner...
Old Jun 7, 2007 | 12:35 PM
BluRR's Avatar
Who is you ******* great tuner?
Old Jun 7, 2007 | 01:52 PM
classicauto's Avatar
Crash Auto?Fix Auto.
Originally Posted by dhahlen
First one - 2 days
Oh how I feel your pain.
My first was 400km until I lost a chunk of apex seal the size of a pen tip while cruising at 5in of vac at 100km/hr. Took out a housing, rotor and turbo. Still can't figure that one out......
Second engine....well I hope it lasts longer then that.
I've had plenty of near-to-stock ones last a long time though
Old Jun 7, 2007 | 05:06 PM
RICE RACING's Avatar
Lightbulb
Well over 200 quater mile passes LOL
hang on that equals 8km of hard driving :P
ok then its been going for 10 years !
hang on, no mention of how hard it was driven or how many km's covered :P
you will get a lot of BS replies in this thread with little qualified data OR you will get lots of claims of sustained performance which depending on the font its typed in and amount of exclamation marks will enforce the point to you and you might believe it if your stupid enough !!!!!!
My 450+rwhp motors generaly will cover 600000km in a 95% duty road cycle and the rest racing cycle (i.e full load/power and full revs, v's cruising revs and low rpm). For full racing duty dotn expect any more than 4000km of reliable service before you need a full overhaul. You can apply this data to numbers of years or fullee hectic 1/4 mile passes and stretch the fact to make it sound even better or more exagerated as required LOL LOL LOL
Old Jun 7, 2007 | 06:03 PM
AImec Racing's Avatar
so ...no time for this
good one!!
it took me 2 engines to learn...then...
the last one is 2 years old...
10,000 daily driving miles
Street racing every thursday on '93 pump-gas, 20-25psi (+100 times)
+100 1/4 miles with T-111 @ 30 psi
+20 shift-misses (over 9000 rpms = no rev limit)
+10 racing times w/empty tank (not enough fuel supply = weird noises)
2 Solo-1 Races (2 heat/days, 4-laps/heat 1.30/ave. per lap) @ 15 psi on pump gas
One time while I was drunk I forgot to activate the secondary pump and race with another FD ... at 3rd shift when load was required it began to do the lean noises,,, I never stopped
One time I unadvertised left a socket inside IC piping and it hold off the TB WOT for 10 seconds until I was able to think and turn the engine off...
...so I would said I finally achieve REALIABILITY!!! HAJA!
... and I don't expect you to believe me... and I don't now how to over size fonts but at least I will use caps: IS TRUE !! JAJAJA!!!
Old Jun 7, 2007 | 09:07 PM
marcus219's Avatar
FC Mobsta
so like 40-60k for over 400rwhp is average motor expectancy roughly?
Old Jun 8, 2007 | 02:59 PM
I am a Jeeper Now.
Crispeed
Old Jun 8, 2007 | 04:22 PM
KNONFS's Avatar
B O R I C U A
Originally Posted by Directfreak
Crispeed
Did he built your engine?
Old Jun 8, 2007 | 05:28 PM
I am a Jeeper Now.
No, I stated that before..
He will be building me other engine. Going for
High HP on that one..
Old Jun 21, 2007 | 02:05 AM
binary89's Avatar
Crispeed
I wish I knew him, maybe If i had enough money to waste I could go single.
Old Jun 23, 2007 | 04:51 PM
willub and company's Avatar
Pobody's Nerfect
No one finds this some what alarming?
Old Jun 25, 2007 | 01:07 PM
Matlock's Avatar
Which part???the drinking and driving while racing? or the pump not being on?Lmao
Oh well it's Puerto Rico.....as long as it's not where I live. My families safe!
cristoDathird
28
May 30, 2019 08:47 PM
elfking
Aug 19, 2015 09:48 PM
Clacor
Aug 14, 2015 09:17 AM
