Super AFC Area is for discussing the Apexi Super AFC
Super AFC earth wire question
Old Jun 4, 2007 | 07:22 PM
NZ_87_TURBO's Avatar
long live the monster BP
earth wire question
The wiring diagrams say to wire the brown ground wire closer to the ecu than the black ground wire.
Im hooking the SAFC up to run with a HKS FCON where it will modify the pressure sensor signal to the FCON which has its own fuel maps.
should i be wire the brown wire closer to the stock ecu or to the FCON ecu???
Thanks
Old Sep 6, 2007 | 10:00 AM
SureShot's Avatar
Seduced by the DARK SIDE
I can only guess that the two seperate ground taps are to suppress high frequency ground noise.
I'd tap it closed to the stock ECU.
The Shaolin
Sep 14, 2015 07:50 PM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
