Over heating?????
Old Jun 3, 2007 | 03:38 AM
drschwinn2002's Avatar
Question Over heating?????
When the engine over heats dose it smoke more?
Old Jun 3, 2007 | 12:22 PM
HEYTOYOTAGUY's Avatar
Be More Specific Is Your Temp Gauge Reading Hot Or Do You Think You Are Over Heating?
Old Jun 3, 2007 | 06:39 PM
No the water temp senser was cut off on the radiator and i ran it around the block and it was vary low on colent and when i got back it started smoking from the tail pipe realy bad. blue smoke.....I dont know if it was overheating that was cousing the smoke or just i realy fucked some thing up or what.
Old Jun 3, 2007 | 07:07 PM
Rx-7Doctor's Avatar
Blue smoke is oil.
If you smelled the odor from the tailpipe it would be a sweet odor not a foul odor like oil.
Old Jun 3, 2007 | 07:38 PM
what dose it mean if it was wight.....
Old Jun 3, 2007 | 08:37 PM
Rx-7Doctor's Avatar
White. Is either fuel or coolant. You will either have a fuel smell back at the exhaust or other. Other will be coolant.
Old Jun 4, 2007 | 01:06 PM
The Doc Is Right Blue Is Oil
White Is Coolant Or Fuel
Doc Do You Think That He Over Heated The Engine Making It Warp And Allowing More Oil Than Normal Into The Combustion Chamber?
Old Jun 4, 2007 | 01:07 PM
Wich Cable Was Cut Anyway Was It The One Ontop Of The Radiator Or The One On The Bottom Of The Radiator?
Old Jun 4, 2007 | 01:52 PM
Rx-7Doctor's Avatar
Normally what happens when you overheat a 7 engine is that the coolant seals go. We do get warpage in our engines but it's not like what you are used to on a conventional piston engine where the cylinder head warps.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
7upra
Mar 25, 2018 11:32 AM
