choke issue (cold start) on 84 SE
Old Jun 2, 2007 | 06:39 PM
Rotary Weasel's Avatar
Resident Weasel
howdy fellow rotor heads,
I have a question for the gurus, is there a way to disconnect or override the automatic choke (cold start high idle) on the F.I. 13b GSL-SE? I've heard the put it in gear trick on the FC's, this doesn't work on the FB E.G.I. My choke is intermittient and tends to make the car idle strangely until fully warmed up, once in awhile it operates perfectly, I.ve been through the intake, tb's, tps etc to no end
I searched the fsm to no avail, finding info on the actually choke system (cold start) is hit and miss.
Thanks for any advice
Old Jun 3, 2007 | 12:58 AM
Rx-7Doctor's Avatar
The fast idle is activated when you depress the throttle once before starting when it is cold out.
I have never seen a thread on the removall of this system.
As we all when a idle issue crops up on a Se it can be many different things.
The best thing you can do is go to the FAQ's where there is about 4 or 5 links for the idle issues and go thru each one.
The idle issue on the Se is one of the most frustrating problems when it occurs.
Old Jun 3, 2007 | 11:01 AM
Resident Weasel
lol, my fast idle comes on by itself, I don't have to depress the gas to get it to come on, it will engage automatically on cold or warm mornings. I have got it somewhat tamed by adjusting the fast idle cam nearly all the way out, it idles at 2500 rpm at startup then fluctuates between 2500 and 1000 with the clutch out, with the clutch in, it holds steady at 1900-2000 rpm until the motor is fully warmed up, then it runs normal, and as I stated somedays it runs perfectly normal, it does give the car quite the personality and sounds mean when it's doing it, lol yup just your standard SE idle issue
Kyo
Apr 13, 2019 09:24 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
FB_Frank85
Aug 31, 2015 03:31 AM
85TIIDEVIL
Aug 25, 2015 12:09 AM
