Power FC Hwl Sensor Flashing On Pfc?
Old Jun 1, 2007 | 03:17 AM
jef57's Avatar
Question Hwl Sensor Flashing On Pfc?
hI,
my exhaust temp warning indicator ( HWL) flashing on my PFC, what does it mean?
my mods :
Hks down pipe
blitz nur spec catback
hks twin power
efini y pipe
mazdaspeed smic intercooler
k&N filter
air separate duct from 99'
apexi power fc base map ( fd3S4)
run with octane 98 OR 100.
Thanks for your help
Old Jun 1, 2007 | 08:21 AM
NewbernD's Avatar
Tequila? ..it's like beer
Your indicator is in the dash cluster, right? Since the US cars have their overheat indicator next to the ashtray (and it's wired differently) that function doesn't work for us unless you do some re-wiring.
My recollection is that it would flash on excessive knock.
Originally Posted by jef57
hI,
my mods :
Hks down pipe
hks twin power
efini y pipe
k&N filter
Old Jun 1, 2007 | 08:54 AM
jef57's Avatar
Hwl Flashing in power fc commander, in "sensor check"
I was thinking i've exceed the capacity of oem boost sensor, since pfc commander read more than 0.87 BAR (depends gear)
Old Jun 1, 2007 | 11:53 AM
rynberg's Avatar
No, the oem boost sensor is good for 1.2 bar or so. You need to go to the sensor screen and see what is out of spec.
Old Jun 1, 2007 | 07:17 PM
skir2222's Avatar
I win
A lot of poeple switch to a GM map sensor during PFC install due to the stock map sensor giving unaccurate readings to the computer
Old Jun 2, 2007 | 01:00 AM
rynberg's Avatar
The stock MAP sensor does NOT give inaccurate readings. Where the hell did you come up with that idea?
Old Jun 2, 2007 | 08:59 AM
Dave Newbern is right with the opinion the flashes shows the excessive Knockreadings.And Dave also in Europe the Indicator for Exhaust overheating is in the Lokation near of the ashtray.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
RE-Mamamia
Sep 11, 2015 02:13 PM
