best turbo to put on FC for fast spool?
Old Mar 28, 2002 | 12:31 AM
FC Drifter's Avatar
Damaged Little F*cker
i want a new turbo, one thats more efficient, and spools faster. i dont neccisarily want to go bigger, just faster response. i want minimal lag above all. what turbine will spool the fastest and isnt that much bigger than my stock 89+ turbo?
Old Mar 28, 2002 | 01:17 AM
bcty's Avatar
Boost This!
KKK titanium turbocharger... try it
Old Mar 28, 2002 | 06:33 PM
RETed's Avatar
How much power you're looking for?
-Ted
Old Mar 28, 2002 | 07:14 PM
FC Drifter's Avatar
my goal for power is 300hp to the wheels. im not looking to make more than that. my goal for 1/4 mile time is mid/low 12s, on slicks. i dont want to run any more boost than i have to. max of 15psi. i will have a fmic.
Old Mar 28, 2002 | 07:22 PM
fcturbo2's Avatar
im going to be using a T04B .60 v trim and .96 P trim and i was told that its good for 350hp. That is my goal with front mount, streetport, and E6k and of course more fuel..Im also going to be staying at 15psi max while drag racing.
Old Mar 28, 2002 | 08:44 PM
FC Drifter's Avatar
what do you spool up at, rpm wise
Old Mar 28, 2002 | 10:47 PM
RETed's Avatar
I would recommend you run a full T04 upgrade.&nbsp This is not cheap.&nbsp To keep spool-up, quick, you can go with a V-trim, which will put down 300 easily at 15psi.
-Ted
Old Mar 29, 2002 | 03:17 PM
fcturbo2's Avatar
the turbo is not installed
TED so will my set-up be good for street??I want something that spools quick just like the stocker.
Old Mar 29, 2002 | 06:18 PM
InfiniIIIREX's Avatar
Get a ball bearing turbo.
Old Mar 29, 2002 | 09:16 PM
RETed's Avatar
Sure, size the A/R down really small and run a divided manifold.
-Ted
cristoDathird
28
May 30, 2019 08:47 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Wolf_
Aug 11, 2015 04:23 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
