AEM EMS Area is for discussing the AEM Engine Management System!
AEM AEM boost control
Old May 29, 2007 | 03:57 AM
Buellmd's Avatar
AEM boost control
Anybody running the GM solenoid and know how to wire it in?? Thanks.
Old May 30, 2007 | 09:15 PM
macszx12's Avatar
I am using the AEM to contorl boost but i am not using the GM sil. i am using the aem sil
Old May 31, 2007 | 02:56 PM
point5chink's Avatar
ive got the gm solenoid. its easy to install...you splice one wire into the boost control pin found. and the other to a switched 12v signal. You can find the pin in the manual for your aem unit. This is NOT the user guide, but the sheet of paper found in the box with your ems that has a pin diagram or alternatively it is a PDF that comes with your aempro software.
Next, in the user guide, hook it up to the wastegate as shown for external wastegates. Your gm solenoid should look just like the one in the user guide.
Old Jun 1, 2007 | 07:08 AM
Buellmd's Avatar
Thanks man. I'll check my paperwork!
MoTeC
Sep 10, 2015 07:58 PM
