Power FC Pfc fan on adj
Old May 27, 2007 | 07:58 PM
Busted7's Avatar
Will work for horsepower
Pfc fan on adj
Im checking for a friend with a pfc, does the pfc controol the fan on. Also how do you adjust it to a lower setting? Thanks.
Old May 27, 2007 | 09:31 PM
twisted7's Avatar
Jake
usually its on the datalogit that you can change the fan settings.
or you can do the fan mod
Old May 28, 2007 | 05:43 AM
BlueTII's Avatar
Banzai Racing
Yes the PFC controls the fans, you can only adjust the temps with the datalogit
Old May 28, 2007 | 10:04 AM
Busted7's Avatar
Thanks for the info. Im trying to help the owner out with a ton of small problems he was left with by his engine installer, i cant belive these guys call themselves installers and charge money for the work i have seen. They couldn't even get the car started to get it tuned months ago becouse they didnt tell the pfc the correct injectors that they installed. At its highest temps the fans kick on at 100* c and it needs to be lowered. Thanks again.
Old May 28, 2007 | 01:48 PM
cewrx7r1's Avatar
Eye In The Sky
Howard, Kyle, and I have pioneered many tuning technics for the PFC, but there are tuners still doing things the old way and missing improvements with PFC.
Why, they do not read forums like this to learn what we have learned over the years. That is why I started selling my tuning notes package. Why should these "professional" idiots make money and not me.
Old May 29, 2007 | 06:31 AM
BlueTII's Avatar
Banzai Racing
If you do not have access to a datalogit, you can install a S5 water temp switch, this will turn the fans on sooner. You are better off just gettin ahold of a DL and programming it correctly.
Old May 29, 2007 | 02:37 PM
cewrx7r1's Avatar
Eye In The Sky
Or do the FAN MOD SW and turn them on when you want. This has been around since the original cooling sustem recall.
Old May 29, 2007 | 07:52 PM
Busted7's Avatar
Since he doesn't have a/c all you have to do is push the a/c button and the fans come on. He it going to St Louis in ? when Steve Kan will be there I just dont want him to burn it or blow it before he gets there. One other question he needs thermostat housing for ast delete, he has a 99 spec witch does not have bolt on relief cap. Will the t11 stat housing fit or does it require a 3rd gen? And thanks again for the help!
Old May 30, 2007 | 01:48 PM
rynberg's Avatar
There is nothing wrong with running around with the default settings (fans turn on at 100C) until it can be adjusted by Steve. The stock ecu doesn't even turn the fans on until 105C!
Old May 30, 2007 | 07:06 PM
Busted7's Avatar
Thanks everyone!
Einheri
Oct 7, 2015 12:23 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
