(WHEELS) Diamond Racing 13's or 15's
Old Jan 19, 2005 | 12:59 PM
shetlen's Avatar
Air Commando
Veteran: Air Force
Question (WHEELS) Diamond Racing 13's or 15's
I'm going to get some diamond racing wheels and dont know wether to get 15x7's or 13x7's would one handle better than the other and would I have to adjust my speedo for the correct speed? Could yall post some advice and pics of both so I can decide please. thank you
Old Jan 19, 2005 | 01:03 PM
RRTEC's Avatar
Rotartist
Well if you are autocrossing and plan on staying in CS or CSP you had better not run 15X7 or you will be running in SM1... Stick with 13X7 or 14x7.
Old Jan 19, 2005 | 01:17 PM
evita's Avatar
If you have non se brakes, then you could run the 13's. The thirteens would offer a bit better weight savings and also be cheaper to put rubber on. My choice would be the 13's as I think they look much better.
Old Jan 19, 2005 | 01:34 PM
perfect_circle's Avatar
could you post a linky? im in the market fir rims also.
Old Jan 19, 2005 | 02:23 PM
shetlen's Avatar
Air Commando
Veteran: Air Force
www.diamondracing.com
Old Jan 19, 2005 | 02:48 PM
BMS2004's Avatar
Frankencar
what are you getting them for? racing? street? if racing what class and group do you run in and such.
BMS2004's Avatar
Frankencar
you also wouldn't have to adjust your speedo if you "adjust" your tire size accordingly.
Old Jan 19, 2005 | 03:22 PM
CHEF_EG_1's Avatar
Rollin' coal and 53mpg!
15x7 is still legal in CSP... but the tire size can't be more than 225.... at least that's what the rulebook last year said.
Old Jan 19, 2005 | 03:39 PM
851stgen12a's Avatar
Off riding sportbikes!
Yea 15x7 is legal, its limmited to tire size... 225 is right.
Go with the 15's. MUCH better tire selection.
Old Jan 19, 2005 | 04:13 PM
wrxracer55's Avatar
on 15" what tire size 225/?/15
Old Jan 19, 2005 | 06:30 PM
shetlen's Avatar
Air Commando
Veteran: Air Force
It's going to be for street
Old Jan 19, 2005 | 06:50 PM
anyon got any pics of them on there car?
Old Jan 20, 2005 | 08:29 AM
jimmdog's Avatar
13" will work on a SE See Avitar
Old Jan 20, 2005 | 10:12 AM
dbragg's Avatar
Say hello to Mr.Wankel
are you looking for wheels for style or what?
Old Jan 20, 2005 | 11:20 AM
BMS2004's Avatar
Frankencar
225/45/ 15's are the closest match if you want to retain an accurate speedo. This is for a car that came with 185/70/r13's from the factory. heres a link to help you.
http://www.miata.net/garage/tirecalc.html
Ron
Old Jan 20, 2005 | 11:24 AM
rob81gsl's Avatar
^^rotard for life^^
i run the 13 x7's on mine and i love them. speedo is off but oh well. the really seem to help the acceleration out of corners in autoxing with that small diameter. kinda weird going to a strip though with those small tires and slightly larger rear end gears and getting well into FIFTH gear in the quarter. i don't have any pics of mine but if your car has been lowered a fair amount they look sexy
Old Jan 20, 2005 | 11:27 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
I like the look of a really wide 13 inch wheel, plus getting tires are much cheaper. If it were me, I'd get the 13's.
Old Jan 20, 2005 | 12:05 PM
shetlen's Avatar
Air Commando
Veteran: Air Force
I want my car to have an aggressive look, ride low, and corner well, will do some drifting and draging at the track.
Old Jan 20, 2005 | 04:00 PM
wrxracer55's Avatar
what size tire would you use on a 13x7 rim?
Old Jan 20, 2005 | 05:06 PM
CHEF_EG_1's Avatar
205/50-15 Falken Azenis fill out the wheel well NICELY.... I've got them on my 15x8" Centerlines, and they stick out a little, but that's what CP Racing's fender flares are for
Old Jan 20, 2005 | 05:16 PM
MosesX605's Avatar
215/50/13 would work quite well. Sumitomo sells tires in that size for the street, and it's easy to get R compounds and slicks in a 215/50/13 size as well.
Old Jan 20, 2005 | 07:03 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
real wide 13x8's on the blue car.
Old Jan 20, 2005 | 10:17 PM
SS124A's Avatar
0000-09-0233
Iwould go with the 13x7.
you can use the 215 tire, and this is a legal wheel size incase you goto IT racing.
Attached is a couple pics of Robs (rob81gsl)car in action.
Attached Thumbnails (WHEELS) Diamond Racing 13's or 15's-rob1.jpg   (WHEELS) Diamond Racing 13's or 15's-rob3.jpg
Old Jan 21, 2005 | 09:54 AM
wrxracer55's Avatar
what backspacing should i get with the 13x7s, 4.5"?
Old Jan 21, 2005 | 10:14 AM
SS124A's Avatar
0000-09-0233
yes,
that is what Rob and I use
