tire question
Old May 20, 2007 | 09:05 AM
stickmantijuana's Avatar
Question tire question
hi guys,
if i want to put down ~600-700whp safely on street tires (~250-300 threadwear) from 50mph --> 120mph'ish, what would be the minimum tire width i need?
would 285/35/19 work?
or is it even possible?
thanks!
Old May 20, 2007 | 09:10 AM
allrotor93's Avatar
Originally Posted by stickmantijuana
hi guys,
thanks!
it will spin everything but a MT slick
Old May 20, 2007 | 11:25 AM
i asked because i've seen some videos of people running supra's and rx7's in the 600whp range on street tires.
probably won't be putting any drag-only slicks on my car...
Old May 20, 2007 | 11:37 AM
patman's Avatar
Resident Know-it-All
i run goodyear eagle f1 275s which are a very sticky street tire, and at 4xx hp they dont stick under around 70. I am planning to try drag radials when i get the 700hp build broke in and see how they work.....
Old May 20, 2007 | 12:43 PM
is there any good traction control system that can help me putting the power down? i see 800whp+ supras regulardly putting the pedal through the floor on youtube everyday and they seem perfectly under control for some reason.
suspension geometry is bit different but still... i do have adjustable coilover and can set the back to relatively 'soft' setting.
when i had 300whp, traction was never a problem once i was over 20mph as long as i didn't drop the clutch.
Old May 21, 2007 | 08:52 AM
calculon's Avatar
On flats
racelogic has been used with some great results.
search for a thread titled something "traction control" in the rotary performance sub forum, I'm the OP. some pretty good discussion in there.
Old May 21, 2007 | 01:12 PM
Juiceh's Avatar
Saiga-12 Power!
The racelogic traction control has been used successfully in 2 rotor applications but I don't think it has been done with a 3 rotor setup yet. I'm very interested to see if someone can get this to successfully work with a 3 rotor. I plan on going that route eventually with my 3-rotor.
Old May 21, 2007 | 03:05 PM
calculon's Avatar
On flats
I do to when I get a bit more dough. . .RICE RACING (one of the successful 2 rotor stories) and I worked out the "programming"/"tuning" that would need to be done to run a 20B with the racelogic in my thread in the rotary performance sub forum. check it out. . .the more input the better
ryan
Old May 21, 2007 | 09:04 PM
calculon, when do you think you'll install one and give it a proper testing on a track?
no matter what people say, a GOOD traction control system WILL make you a faster driver on a track! didnt' think they made a good after-market tcs... RL does look quite promising
i also have a 3rotor, so naturally i'm very interested to see the results.
try doing a full circle with tcs @ full throttle! hope it'll be a nice controlled slide, not an ***-wiggle haha
Old May 22, 2007 | 09:11 AM
calculon's Avatar
On flats
Probably not for a while (at LEAST ~6months) . . .i was all primed to order it, and then some other more important things came up. . .
i know i know, what's more important than a 20B FD with TRACTION??!?!?
I agree with you completely in so far as it making you effectively a better driver. . .if I didn't want to build this house, I'd be letting you know. I encourage you to be confident in what RICE and I pounded out, it makes real good sense if you read the RL manual.
if you do take the plunge, be sure to post back.
either way, good luck
ryan
Old May 22, 2007 | 10:43 AM
felix_is_alive's Avatar
i run toyo proxes T1s` 285/35/19 they are "decent" to about 10 psi (still spins though ) which is `bout 400 something so i am figuering 600 700 , street tires ....it will spin the **** out of mostly anything
this of course ,is on the street , on the track i wouldn`t know
Barrman
Sep 8, 2015 03:25 PM
mazdaverx713b
19
Aug 29, 2015 12:30 PM
