Double throttle diaphrams and delay valves vs check valves
Old Mar 26, 2002 | 07:36 AM
HAILERS's Avatar
HAILERS
Does anybody out there know why, on a 88 model, there is a DELAY VALVE between the water thermo valve and the double throttle diaphram on the N/A car, but on the turbo model there is a CHECK VALVE between the water thermo valve and the double throttle diaphram????
Old Mar 26, 2002 | 07:50 AM
Josepi's Avatar
Despise Enmity
I can't believe your asking a question
Old Mar 26, 2002 | 08:21 AM
HAILERS's Avatar
HAILERS
Got a lot of questions. Usually don't get an answer, therefore don't ask questions. Make sense.
Old Mar 26, 2002 | 08:57 AM
Vroomaster's Avatar
If in doubt.....take it off and see what happens
j/k
Is it actually different, or or just called diferent names?
Old Mar 26, 2002 | 09:00 AM
Turblown's Avatar
Turn up the boost
what the difference between the 2 vavles?
Rotary Performance Parts
Old Mar 26, 2002 | 09:19 AM
HAILERS's Avatar
HAILERS
The one in the turbo is a check valve that holds vac forever, and the one in the na is a delay valve that holds a vac for 9-15 seconds.
Old Mar 26, 2002 | 10:47 AM
Bambam7's Avatar
I came, I saw, I boosted.
Hold vacuum from what end/direction?
Could be since the TII runs under positive manifold pressure sometimes... you want to keep vacuum in the lines.....
I have never looked closely at a TII engine.
Old Mar 26, 2002 | 10:51 AM
HAILERS's Avatar
HAILERS
Hold the vacuum b/t the valve(check valve or delay valve) and the double throttle diaphram. Double throttle diaphram is connected to the linkage for the secondary throttle plates.
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
