fuel pulsation dampner
Old May 7, 2007 | 01:34 PM
czseven's Avatar
czseven
pleasr help searched but nothing i know it is out there but a little help would b much appericated. How do you depresurize the fuel lines before replacing the fpd.Or can you just uncrew the gas cap and have a towel handy when unhooking?
Old May 7, 2007 | 01:46 PM
Mahjik's Avatar
Mr. Links
The "proper" way is to start the car, and then pull the fuel pump fuse. The car will stall and stop.
However, there isn't a lot of fuel in the system. You can simply open the gas cap to release most of the pressure. There will be a little fuel spillage when you disconnect the FPD and FPR lines, but it won't be much. I would recommend pulling the primary and secondary rail together to replace the FPD.
Old May 7, 2007 | 01:48 PM
C's-7's Avatar
http://www.rx7.org/Robinette/release_fuel.htm
Old May 7, 2007 | 01:52 PM
czseven's Avatar
czseven
thanks bro you are verry helpfull hereon the forum thanks again
Old May 7, 2007 | 02:03 PM
rynberg's Avatar
This is a basic question best answered simply by reading the FSM, which you should be doing anyway -- page F-95.
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
