Power FC 'fuel' highlighted in the sensor menu?
Old May 4, 2007 | 12:23 AM
puffxy's Avatar
I did a little search and concluded that this is referring to the fuel temperature sensor, which is apparently located on the secondary fuel rail. I'm running a kgparts rail and wondering if there are any real negative side affects of just leaving it like this? since it apparently is used to change the amount of fuel ever so slightly if fuel temp goes up, I'd like to make sure that there aren't any incredibly negative side affects of letting it chill as is. I'm reading 4.98v on the commander..
Old May 4, 2007 | 06:50 AM
Fish's Avatar
So long as the car is properly mapped it shouldnt be an issue. I've been running without the sensor for 3 years.
Fish
Old May 4, 2007 | 09:40 AM
cewrx7r1's Avatar
Eye In The Sky
DL Settings 2, did you also change the INJ vs FUEL Temp 60C value to 1.00?
Old May 7, 2007 | 09:35 AM
Aeka GSR's Avatar
mine does that because it is unplugged. I haven't had any issues.
Old May 11, 2007 | 11:24 PM
puffxy's Avatar
for those of you that have it unplugged, does the exhaust temp warning light come on? seeing as how the sensor is obviously not there?
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
