oil level sensor harness question..
Old May 2, 2007 | 05:16 PM
supraturbo1987's Avatar
If the wire/plug coming from the oil level sensor outside of the pan breaks off so close to the sensor that you can't solder a new one on, am I forced to get a new pan with the sensor in it already? There are 3 10mm bolts going into the sensor from the outside of the pan...when I remove those, it won't budge. Looking at my spare pan which is NOT on the car, it looks impossible to replace the sensor without replacing the pan...am I correct in this?
Trev
Old May 2, 2007 | 05:29 PM
books's Avatar
I have replaced the o-ring between the sensor and the pan, although that was performed out of the car. The sensor and the pan are 2 separate pieces.
Old May 2, 2007 | 08:02 PM
Busted7's Avatar
Will work for horsepower
You can replace it its easy. But i was able to soilder mine just cut it and put a bead of soilder down first then add the wire. Oh i removed it first and cleaned it.
Old May 3, 2007 | 01:04 AM
Monkman33's Avatar
Goodfalla Engine Complete
heck. since the wire is busted off the sensor should be easy to remove.
Old May 3, 2007 | 08:59 AM
I will examine it further. It must just be stuck in place.
Trev
Old May 3, 2007 | 10:19 AM
Busted7's Avatar
It has an o-ring seal.
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
Aug 18, 2015 02:46 PM
