Removal of passenger side door panel
Old Apr 29, 2007 | 09:08 PM
RISEN's Avatar
I removed the driver side door panel with ease but I'm having some trouble removing the passenger side door panel. It seems as though there is a bolt holding the panel to the door right where the handle bar is located. However, I cannot seem to find this bolt. I tried tugging but I'm scared the door panel might snap in half due to excessive force.
Old Apr 29, 2007 | 09:13 PM
nashman69g's Avatar
Boost Addict
you need to take the window switch out and you will see the bolt.
Old Apr 29, 2007 | 09:15 PM
bajaman's Avatar
Constant threat
Yes, you MUST pull out the window switch and access the screw behind it!
Old Apr 29, 2007 | 09:26 PM
RISEN's Avatar
Ahh...this dirty little guy?
Old Apr 29, 2007 | 09:28 PM
check out Dale Clarks web site. he shows it all in the how to section
Jeff
Old Apr 29, 2007 | 09:31 PM
NTIMD8's Avatar
Jeff
Yup, used this site when I took mine off and because of the how to it was very easy.
Here is the link for the passenger side how to....
http://www.clubrx.org/default.asp?id...ntent=23&mnu=5
Old Apr 29, 2007 | 10:38 PM
rynberg's Avatar
All of this stuff is in the FSM, section S.
Old Apr 30, 2007 | 11:06 AM
RISEN's Avatar
Thank you guys/gals for the helpful information.
Old Apr 30, 2007 | 04:50 PM
cewrx7r1's Avatar
Eye In The Sky
Lightbulb
You newbs need to learn how to find and use the manuals.
Doing so will help your confidence and knowledge more than JUST ASKING.
Why do you think we experienced owners know so much, we learned mostly on our own, and are not afraid to tackle something new with only our own knowledge.
Old Apr 30, 2007 | 05:11 PM
RISEN's Avatar
Sorry, master. I just purchased the RX-7 last week. Didn't see the sticky stuff, but at least I know now and knowing is half the battle.
Old Feb 26, 2010 | 06:30 PM
millennm's Avatar
This post is helpful. Therefore, I had to add my 2 cents.
Home Depot has 3M Friction Tape in their electrical department.
Put some friction tape on the end of a screw driver. Then push the screwdriver into the slot between the window switch and door handle. While pressing the screwdriver into this slot, pry toward the window switch.
Monsterbox
Jul 29, 2022 10:48 PM
runner83
1st Gen General Discussion
16
Aug 26, 2015 05:16 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
