Since searching is messed up....
Old Apr 27, 2007 | 07:41 PM
lechnoid's Avatar
Wheeeeeeeeee!
I'm planning on removing my air pump but can't seem to find info on routing the serpentine belt. Do I just shorten to about a 30" or 30 1/2" belt and have it only touch about 1/6th of the water pump pulley, or am I supposed to go a bit longer and have the water pump spin the opposite direction?
Old Apr 27, 2007 | 07:55 PM
3GRX7's Avatar
Rotary!
Don't do it half-assed. Get a pulley kit:
http://www.rx7store.net/product_p/rx...%20pulleys.htm
Old Apr 27, 2007 | 08:11 PM
lechnoid's Avatar
Wheeeeeeeeee!
Are these pulleys the same size as stock or different? If so, how much larger or smaller are the pulleys than the stock one?
Old Apr 27, 2007 | 08:51 PM
Mahjik's Avatar
Mr. Links
The pulley is larger. The problem is that without the airpump in place, the contact with the waterpump pulley is less and can slip at higher RPM's. The Greddy pulley kit enlarges the alternator pulley to allow better contact with the waterpump pulley and reduce the chance of the belt slipping.
Old Apr 27, 2007 | 11:17 PM
lechnoid's Avatar
Wheeeeeeeeee!
Thanks for the easy info guys!
Sethix
Nov 3, 2017 11:48 PM
Jmolina0163
Oct 3, 2015 10:04 AM
Robrods64
Oct 2, 2015 07:56 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
Jingkun
Sep 28, 2015 01:53 PM
