i got butter in my oil!!
Old Apr 25, 2007 | 07:02 AM
frisc's Avatar
improvisor specialist
i went to add some oil in my car today and when i opened up the top i saw what looked like butter/snot! Just like in a piston engine when you blow a head gasket... im worried if this is a major problem or not. I read another thread on this board and a guy said that condensation could of caused it...?? I have smoke coming out the tail pipe but i think its because im running rich. The cars drives fine and under boost i blow some blueish black smoke sometimes but i havent seen any white smoke. I changed the oil and it looked fine ....any advice
Old Apr 25, 2007 | 07:27 AM
pugg57's Avatar
proper motoring
does the smoke smell sweet?
if everything is running fine, i personally, wouldn't worry about it too much, but i would keep an eye on the oil. check your level frequently and make sure its not going up. if it is, you could be getting some coolant into it. maybe replace it again in 500 miles or so and see if you get the same "butter" stuff on it.
Old Apr 25, 2007 | 08:33 AM
Sgtblue's Avatar
Urban Combat Vet
Typically it's condensation, usually from short drives that don't allow the car to get to full operating temp or to stay at operating temp long enough to dry it out. It also seems to be more common in spring or fall, probably because it's cooler out.
Old Apr 25, 2007 | 09:16 AM
DaveW's Avatar
Racecar - Formula 2000
Condensation in filler neck
I get this all the time, especially when it is cool out. If you are not losing coolant, don't worry about it.
Dave
Old Apr 25, 2007 | 03:03 PM
frisc's Avatar
thanks for the replys
Old Apr 25, 2007 | 03:10 PM
iceman4357's Avatar
mine does it as well. It smells sweet a little. But i think it could also be from my alcohol inj
Old Apr 25, 2007 | 03:26 PM
rx slim's Avatar
Butter, oil. . . . add some garlic and put it on toast.
MMMMmmmmmmmm.
Old Apr 25, 2007 | 04:50 PM
Monkman33's Avatar
Goodfalla Engine Complete
Ham on rye with 90w gear oils tastes pretty good too.
Old Apr 25, 2007 | 06:32 PM
bajaman's Avatar
Constant threat
Pennzoil does this all the time.
Old Apr 25, 2007 | 06:56 PM
RE-Amemiya7's Avatar
Ditto
Old Apr 25, 2007 | 07:41 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
yep.
my old GSL-SE had a bad thermostat, and did this by far the worst of any rx7 I've had.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
