Broke turbo stud for Y-pipe
Old Apr 23, 2007 | 11:20 PM
ArmenMAxx's Avatar
I was tightning it, and didnt seem to get tight, so i continued until one of the stud/bolts broke. What can i do about this? Does it come out, and if i do where can i get a replacement stud.
Also, where do they sell the gasket for the turbo/y-pipe?
Old Apr 24, 2007 | 07:04 AM
dgeesaman's Avatar
I think you can get another stud. Look up the p/n in the parts list (linked in the sticky thread about technical downloads)
This time don't overtighten it. Get a small torque wrench and use it until you get a feel for how much torque one of those small nuts actually needs. You probably applied 5x more than necessary to break it.
Dealer again. Cheapest dealer is malloy mazda; contact info is in the FAQ.
Old Apr 24, 2007 | 11:34 AM
wtgator69's Avatar
I did the same thing a few years ago... I even broke an EZ out off in it trying to get it out... I ended up having to take the turbos off and to a machine shop to have them take it out, then tap a bigger hole, now I use a bolt in that one. My advice is to be as carefull as possible because it can turn into a nightmare.
Old Apr 24, 2007 | 12:28 PM
ArmenMAxx's Avatar
i really hope i dont have to take my turbos out.
What way do you recomend me to taked the stud out?
Old Apr 24, 2007 | 05:40 PM
wtgator69's Avatar
I honestly could not tell you, I broke the EZ out off in the stud, and that was too hard to drill through with anything that I had. Hopefully someone who has been successful will chime in.
Old Apr 24, 2007 | 06:11 PM
bryant's Avatar
bryant
can you see any of the stud? stud puller...sears or any craftsman dealer
if not you will have to take it to a welder, they can weld something to the stud and turn it out with heat??
but im not sure what ill effects it could cause.
maybe mechine it out but i hate having diff nuts and bolts.
Old Apr 24, 2007 | 06:52 PM
ArmenMAxx's Avatar
if i take out the y-pipe, a good piece sticks out. Can it screw out? I oredered the stud from the dealer and it looks like its threaded on both sides.
Old Apr 25, 2007 | 07:36 AM
bryant's Avatar
bryant
yes.
get a stud puller and unscrew it.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
