Sponsored by: CARiD
I have been trying to troubleshoot my turbos!!!!
Old Mar 23, 2002 | 07:21 PM
JAMMNN's Avatar
I have been trying to troubleshoot my turbos because I cant get the primary to sproduce more than 8 lbs of boost so I have been troublshooting the best I can from this web site (By the way this is an excellent site!)
http://home.istar.ca/~dvandit/Turbo...eshooting.shtml
5) Check vacuum chamber's storage ability with engine off
Pull off vacuum hose at Charge Relief Actuator
Should hear air entering hose vacuum, re-attach hose
Start engine - briefly accelerate engine to WOT in neutral again
Turn engine off - KOKO 6 TIMES
Watch Charge Control Actuator work each time
Watch Turbo Control Actuator work each time, (need to crawl under the car to see this one)
I know my Charge Control Actuator works because of the test above but my Turbo Control Actuator does not move. I can get it to move using a vacume pump but not with the KOKO test. Any ideas on my next steps?
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
Skeese
65
Mar 28, 2017 03:30 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
