My 20b engine at the dyno test
Old Apr 16, 2007 | 06:20 PM
ABIEX's Avatar
What do you think about this???
Its done on a superflow 901, and the power is corected.
The avg: power between 5500rpm-8000rpm is 750 HP and the Trq lb-ft is 585
Peak: 825.6 hp and 641 lb-ft (895Nm)
Max boost: 28.7psi
http://www.youtube.com/watch?v=cYaLOFAOm-Y
/ Gabi
Old Apr 16, 2007 | 06:35 PM
diabolical1's Avatar
before all the nay-sayers and critics start tearing you down about dyno-types and such, let me be the first to say a job well done.
is that the intercooler you're going to be using on the car or is it just for the dyno? it looks unbelievably ... ahem ... large.
Old Apr 16, 2007 | 06:44 PM
ABIEX's Avatar
First of all thanx.
The IC looks big but its not enough... 127-153 fahrnheit was the intake temp... so a biger IC or I have to shoot some NOS on it to keep it cool or maybee water ( cheaper).
Ones again Thanx!
Old Apr 16, 2007 | 06:46 PM
one of the drawbacks of pics, i guess ...
you're very welcome and enjoy your motor and car, man.
Old Apr 16, 2007 | 06:54 PM
ABIEX's Avatar
If you guys wants to see how the diagram looks like...then here it is.
Old Apr 16, 2007 | 06:56 PM
ABIEX's Avatar
...... Thanx agian!
Old Apr 16, 2007 | 07:07 PM
Juiceh's Avatar
Saiga-12 Power!
I've got wood!
Old Apr 16, 2007 | 07:14 PM
ABIEX's Avatar
Originally Posted by Juiceh
I've got wood!
But the difference is that mine is real and not made of wood or plastic
Old Apr 17, 2007 | 08:52 AM
mirabile's Avatar
beast. How about some more pictures of the car? and the engine?
Old Apr 17, 2007 | 10:01 AM
kenfromqueenz's Avatar
20beast
Congrats man. I have a question though... what kind of tranny are you using to handle your 20beast?
Old Apr 17, 2007 | 05:44 PM
Tim Benton's Avatar
FD title holder since 94
nicely done.
Tim
Old Apr 17, 2007 | 06:01 PM
ABIEX's Avatar
My brother is the cameraman ... He will put some pics on this forum soon...
/ Gabi
Old Apr 17, 2007 | 06:04 PM
ABIEX's Avatar
Thanx!
Chris at CKperformance New York built my tranny (AODE 4 speed Race tranny) and it will handel about 850lb/ft
/Gabi
Old Apr 17, 2007 | 06:05 PM
ABIEX's Avatar
Thanx Tim
/ Gabi
Old Apr 17, 2007 | 06:50 PM
ABIEX's Avatar
Do you guys know turbos that can realy handel 1000hp???
the 76mm inducer was to smal...... I need something that can handel more power but It should not be biger in size outer size than the HX60 that I used!
Thanx in advance/
Gabi
Old Apr 17, 2007 | 08:08 PM
CMonakar's Avatar
rebreaking things
Sounds pretty evil . How is the SM4 working out? Any dyno numbers at around 15 psi?
Old Apr 17, 2007 | 09:57 PM
rarson's Avatar
That's a freaking nice powerband.
I've seen videos of your car before on Streetfire, awesome car. It'll be interesting to see this engine setup in the car.
Old Apr 18, 2007 | 03:47 AM
ABIEX's Avatar
About the SM4 it sucks....But I changed the setup that autronic gave me cuase it missfire all the time, I does not work with seq ignition setups... so I used only 3 spark plugs first I used all 6 plugs and the result was very bad even if I did 0 split it could not managed the burn the mix, autronic told me that they would send me there newest box that is in prototyp mode but the did not send anything, they are claiming the factory that manufacture the circuit boards has not been finished.
About the 15psi numbers are....500.9 hp and 469.8lb-ft @ 5600rpm.
I tuned it very soft on the ignition.... I am using E85 ( 15% gasoline and 85% alcohol) And when the pressure is around 15psi the ignition is 10-11 degrees.
You need more igniton timing to make it burn more clean when using E85.
I am going to use the SM4 this summer, and next year change to somthing else.
/ Gabi
Old Apr 24, 2007 | 05:04 PM
wankeltrim's Avatar
Rotary tuner
Go Gabi...go Gabi
Nice engine !!!!
Old Apr 25, 2007 | 02:06 AM
TheAbsence's Avatar
s4 Pride
Very nice! Bring that down to Sevenstock in Southern California next Fall!
Th0m4s
Feb 26, 2019 02:04 AM
efini7
Test Area 51
Sep 4, 2015 02:59 AM
morataya
Microtech
Aug 17, 2015 01:04 PM
