Enkei RPM2
Old Apr 11, 2007 | 02:18 AM
HobbeZ's Avatar
Enkei RPM2
looking to pick up a set of 17x9 with a +40 offset for my autocross track wheels. I am currently running koni yellows and RSR spings (not the race ones). I've tried all the caculators "will it fit" and apparently they do but they will fit but not by much. I was wondering should i go with something staggered instead? i'm getting a pretty good deal locally on them, but i'd hate to buy them and be left with a junk setup. opinions are welcome thank youoh this is for an fd
Old Apr 11, 2007 | 09:39 AM
Mahjik's Avatar
Mr. Links
Those will fit, but not without a little effort. You'll most likely need a fender roll which I would recommend with aftermarket wheels and a lowered car regardless.
I would recommend running a staggered tire setup with those offset though, probably 235 F and 255 R. Running the 235 up front should help with rubbing issues.
Old Apr 11, 2007 | 10:42 AM
gracer7-rx7's Avatar
needs more track time
I run 17x9 with a +45 and 255/40/17 on Konis with H&Rs. It just fits but not much extra room. I know a few people that tried the same setup on a +40 and it rubs.
235 and 245 would allow more clearance. Not sure what the overall diameter works out to be with 245s. So would a different offset.
Old Apr 13, 2007 | 04:16 AM
RX7Crazy_84's Avatar
umm i am looking into same wheels as well but they only come in two size and two offsets here is the link for it, i was thinking about going 17x9(45 offset) in front and 18x8 (35 offset) in the back but not soo sure if the front one would fit and back one?
http://64.233.167.104/search?q=cache...lnk&cd=1&gl=ca
Old Apr 13, 2007 | 08:46 AM
Mahjik's Avatar
Mr. Links
IMO, you'll be better off with the 17x9 +45 all around. If you "really" wanted a more aggressive look in the rear, you could use a spacer.
I would not put a 9" wheel in the front and then a 8" wheel in the rear.
Old Apr 13, 2007 | 08:50 AM
Mahjik's Avatar
Mr. Links
Oops, just looked at the link. I'm assuming you mean 17x8. In that case, you could run that but I would probably run the same size all around. You can get the +45 in the 18x8:
AutoRND
Old Apr 13, 2007 | 11:50 AM
well i wanna run 17's in the front and 18's in the back, but is it better to run the same size all around? would i have any rubbing issues wit 18x8(45) and 17x8(45)
Old Apr 13, 2007 | 02:48 PM
Mahjik's Avatar
Mr. Links
You do realize that your overall diameter with the tire is going to end up being about the same as stock 16" with 225's regardless of 17 or 18's (unless you don't care about your speedo)?
So all you'll end up with is more sidewall in the front than in the rear. I'm not sure what that accomplishes but the +45 offset will not be a problem for fitment on a 8" wide wheel.
Old Apr 13, 2007 | 04:04 PM
i do care about my speedo ya i dont wanna end up with same sidewall as stock. wat are my options then sorry tryin to figure this whole thing out
Old Apr 13, 2007 | 04:17 PM
Mahjik's Avatar
Mr. Links
The real question is what are you trying to accomplish?
Using a 17" wheel, will give you less sidewall with a 16" when keeping the same overall diameter. Basically, the way to think about is say with the tire, the stock wheels are 20" (making up this number) in diameter with 16" of that being rim so 4" of sidewall.
If you run a 17" wheel in the front and then an 18" wheel in the back, you'll have 3" of sidewall in the front and 2" of sidewall in the rear. Is that the look you want?
The cars that generally do this are generally designed to run a lower profile tire up front with the smaller rim. The RX7 was not designed that way. IMO, you'll be better off running 17x8 or 18x8 all around as you'll be able to rotate tires around to maximize your wear.
Old Apr 13, 2007 | 05:06 PM
well i guess i wanted to do something different like same setup as corvette 17's in the front and 18s in the back, not really that i dont want that look if u put it that way i think it ll look stupid!
Old Apr 17, 2007 | 02:43 PM
dw89s5's Avatar
i know nothing
You probably dont want to do that because more sidewall means more flex it could cause the car to understeer. The corvette was designed to have different size rims but with the same amount of sidewall.
Old Apr 17, 2007 | 08:59 PM
yaa got it!understand it now lol
Old Apr 20, 2007 | 06:01 PM
oh k well i think i am goin go with 17x9 and 18x9 what u guys think of that? not soo sure as i am still thinking about it
