Power FC car not learning idle
Old Mar 27, 2007 | 12:40 AM
JEDlocks's Avatar
Vagina Destroyer
i just installed my power fc. its a brand new unit.
i did everything step by step according to dale's instructions.
i did the idle process, but my car doesn't seem to be learn it.
i tried a few times (i resested the pfc each time).
Anyone have advice?
Old Mar 27, 2007 | 12:49 AM
JP's 93 fd's Avatar
how is your car reacting after the pfc is installed. check out my thread and see if it might work for you.
https://www.rx7club.com/power-fc-forum-47/new-owner-power-fc-627921/
Old Mar 27, 2007 | 02:27 AM
JEDlocks's Avatar
Vagina Destroyer
thread sort of helped, but i dunno.....
my idle bounces from about 500 rpms to about 700.
what is the ISC?
Old Mar 27, 2007 | 02:31 AM
JEDlocks's Avatar
Vagina Destroyer
oh and the car chokes really bad. i did the whole idle screw 1/2 turn thing, but it still wont idle right.
quick question: does the elbow have to be on while idling? i tried it with it on and with it off so i can adjust the screw.
Old Mar 27, 2007 | 11:56 AM
Noxlupus's Avatar
One thing you might want to double check; make sure tha the PFC is the right model for your vehicle. In otherwords, check the Serial number and compare it to Dale's PowerFC FAQ document to make sure it matches with your model.
Old Mar 27, 2007 | 12:07 PM
JEDlocks's Avatar
Vagina Destroyer
its the correct model.
i tried it again this morning, and now my car bogs out and dies after 5 minutes
Old Mar 27, 2007 | 02:20 PM
Noxlupus's Avatar
If it's boging down then your idle bleed screw isn't set properly. Open it up alittle. Try setting it about half a turn out from fully in.
Old Mar 27, 2007 | 04:06 PM
JEDlocks's Avatar
Vagina Destroyer
tried that too
Kyo
Apr 13, 2019 09:24 AM
sYnth.
Aug 17, 2015 07:28 PM
ncds_fc
Aug 15, 2015 10:06 AM
